Spraying over latex paint
2/20/21
mastercabman
I do a lot of cabinet refinishing.I usually get jobs where it is a factory cabinet that is stained and the homeowners wants to have them painted
What I do is Scuff them, clean them with Naphtha,then use a white vinyl primer and then top coat with the color of their choice
Most of the factory cabinets are sprayed with a solvent based product like CV or pre-cat so that makes my work pretty compatible
But I do have a job coming up that I will be replacing all the doors and drawer fronts so I'll just use a CV like the MLC Turino that just started to use
But the cabinets are made of pine and previous owner painted it white with what looks like latex and it was brushed on
So scuffing the cabinets only is not going to be a good way to prep for my go to finish
I guess I could go ahead and sand the cabinets to bare wood
That is a possibility since the kitchen is pretty small and face frames are just narrow flat surface and there's only 1 side of a cabinet showing
Or I could use another product on the cabinets that would be more compatible with latex
What would you do?
And if you would just paint over the old latex what products would you use ?
2/20/21       #2: Spraying over latex paint ...
Nick
When it comes to refinishing (l've done a lot of it), the rule l've ways lived by is; "never put something harder over something softer(more flexible) as it's akin to painting a balloon...as the top coat will crack. Look into using SW's Emerald urethane acrylic; flexible and eventually dries/cures pretty hard.
(2-3 days)If you're on the west coast, l've been using Dunn Edwards 'Aristoshield' for this application with great results,it's a modified alkyd urethane acrylic...slower drying and curing but after a couple of days on the racks in the shop @ 70+ degrees it's good to stack and pack.
2/21/21       #3: Spraying over latex paint ...
mastercabman
Thanks Nick
I think I might go with SW emerald
It's a small project and I talked to the homeowners into full overlay look so that most of the face frame will be covered with the new doors
On another note,I have an Asturo spray gun with a 2.5 nozzle and thinking of using it to spray the Emerald
I know I will need to thin a little but do you think it will be ok?
Again,it's a small kitchen with only 1 side that is exposed 30" x 12"
Everything else is face frame
2/21/21       #4: Spraying over latex paint ...
Nick
The 2.5 will work great. I usually break out the airless using a 410 fine finish low pressure (those low pressure tips from Graco are amazing) when spraying paint but if l'm just spraying 1 door l have Sata 1000b with a 2.0 that sprays the Emerald great with just a little water added.
2/25/21       #5: Spraying over latex paint ...
BH Davis  Member
Maybe a bit low tech but I'd prime with Bin and then top coat with the latex. I've never had a Bin (white shellac) bonding coat fail on interior use, and the latex will adhere to it just fine.
3/6/21       #6: Spraying over latex paint ...
Daniel Shafner Member
When we spray latex we use a a 1.4mm tip. The latex is thinned with 10% water. Spray it, let it dry. Dry sand with 600 grit and spray it again.
