Polishing Polyester or use an alternative topcoat
3/8/21
craig Member
Having a tough time with polishing polyester. The items I'm coating are contoured so machine polishing isn't a good option as it wears through on high spots
Im using a small 3" pneumatic polisher but results can be very average even starting at 1000 grit.. I would even consider using the polyester to get the fill and build then possible final coat with an easier to polish finish? Anyone have a suggestion to a final topcoat?
3/8/21       #3: Polishing Polyester or use an alter ...
Chris
I use a 2K urethane from Ilya
3/10/21       #4: Polishing Polyester or use an alter ...
craig Member
What process are you using?
I'd like to try a wet on wet system if possible.. finishing with the polyurethane.
3/10/21       #5: Polishing Polyester or use an alter ...
chris
i use the polyester to fill the grain on table tops then sand flat.
i then seal and topcoat with the ILva 2K urethane.
3/11/21       #6: Polishing Polyester or use an alter ...
craig Member
Whats the dry time like with the 2k urethane?
3/11/21       #7: Polishing Polyester or use an alter ...
chris
I can polish it the next day
3/11/21       #8: Polishing Polyester or use an alter ...
craig Member
wowzers! Got a product number on that?
Is it easier to polish than polyester? I presume so as polyester is the hardest finish Ive ever tried.!
3/11/21       #9: Polishing Polyester or use an alter ...
Chris
TA0012 acrylic sealer
TS000 acrylic topcoat different sheens.
I use this as it is totally clear but you can use polyurethane too
Go to IC&S website to see all ILVA products
3/15/21       #10: Polishing Polyester or use an alter ...
craig Member
Thanks!
