Replacement for Charles Neil's Blotch Control
3/17/21
David Waldmann Member
Website: vermonthardwoods.com
We have been using this for several years. We understand that Charles passed away in late 2019, and although we have purchased it a few times since then, the website is now down and the phone does not get answered.
Does anyone know of a comparable product?
Thanks,
David
3/18/21       #2: Replacement for Charles Neil's Blot ...
DannyB Member
Hey, what do you use it with?
Acetone based spray dyes often flash enough that they blotch a lot less.
If you need a pigment stain, use MLCampbell's amazing stain, which is meant to control blotching and works very well (IMHO).
https://www.mlcampbell.com/product/woodsong-amazing-stain-base/.
The
re are equivalents from most other manufacturers
3/19/21       #3: Replacement for Charles Neil's Blot ...
Update:
The site we used to use, and the one that searches turned up, has been replaced by another one. We found it by searching for images of the blotch control. It was in stock and ready to ship. We placed an order so I guess we will have to see if we get it...
We use it on Cherry for three different water based spray stains we do. Interesting to hear there are stains that have something like that built in, but this works, and trying to match something new is always a challenge. I will, however, keep that in mind. Additionally, I got a call from someone at Aqua Coat and they are sending me a sample of their product - we'll try it out and keep that as a backup if it works out.
3/19/21       #4: Replacement for Charles Neil's Blot ...
Nicko Member
I think I read somewhere that CN blotch control was glue size. I have used it before and thought it worked great.
Nicko
3/19/21       #5: Replacement for Charles Neil's Blot ...
duster
In the past I've used a product called Nelsonite for blotch control on pine, maple, and other species. It's marketed as a wood stabilizer to reduce shrinking and swelling from humidity changes. It works pretty well to reduce blotches, and it seals end grain so it doesn't absorb so much pigment. You just brush it on raw wood and let it dry overnight before you apply the stain.
3/23/21       #6: Replacement for Charles Neil's Blot ...
Robert Member
Try wiping down Cherry with Paint Thinner and while still wet/damp apply your oil based stain. Works quite well on end grain too.
3/23/21       #7: Replacement for Charles Neil's Blot ...
Thanks, but as I said:
"We use it on Cherry for three different water based spray stains"...
3/23/21       #8: Replacement for Charles Neil's Blot ...
Robert Member
Yer right David and I shouldn't have posted the reply. It was mainly for others using an oil based stain who were trying to dodge the blotching issues. My bad for veering off original topic.
2/7/24       #9: Replacement for Charles Neil's Blot ...
james elder
do you still have a source for Charles Neil's Pre-color conditioner?
thanks
jelder
