Kitchen cabinets repaint
4/6/21
Bart
Maybe mastercabman could jump in on this one.
I've got client who wants me to refinish their existing 6year old pigmented CV off white kitchen. We just built/finished a large master closet project for them. My thinking is using my usual GF pigmented poly over Bin shellac prime, GF white undercoat then two top coats of tinted white poly. I'll pull off all removables and finish those in the shop.
The only monkey wrench are the kicks and lots of 6" base and a fair amount trim work which I'm thinking brushing would be easier on a lot of this. I'm considering using Cabinet Coating by Insl-x. Does anyone have any experience with it?
BTW, I'm subbing out most the onsite prep and any trim to painter friend and his son. I'm just overseeing and shooting whatever I can in the shop.
Any thoughts and advice would be welcomed.
cheers
Bart
4/6/21       #2: Kitchen cabinets repaint ...
rich c
Refinishing is the devil's work. Just act as the general contractor and let the painters handle it. If they don't remove all the cooking oils and grease and you bring that into the shop, you are in for a real mess.
4/7/21       #3: Kitchen cabinets repaint ...
mastercabman
Bart
Looks like you have a game plan that should works
As far as kick plate for the cabinets
90% of the time I rip and cut new kick plate out of 1/4" MDF
Sometime I can pull the old one off and repaint them
For the trim I would just brush on paint to match
But if I have to spray crown molding that is nailed to the cabinets I sand the profile with my surf prep sander and clean with Naphtha
And since I like to use a CV I use a white vinyl primer
Hope this helps
4/8/21       #4: Kitchen cabinets repaint ...
Bart
Thanks mastercabman,
What are you using for clean up? Krud Kutter or tsp followed by some kind of wash?
Thanks again.
4/8/21       #5: Kitchen cabinets repaint ...
Jonathan Mahnken
wash with tsp and scotchbrite. rinse with water and a sponge or towel. Some dont, but I sand with 220 after. Then use stain blocking primer, and paint. What makes it devils work is when you dont wash well enough, and use a stainblocking primer.
4/9/21       #6: Kitchen cabinets repaint ...
mastercabman
Cleaning,sanding, prepping is 80% of a successful finish!
I have been pretty lucky with jobs that I refinish
Most of them are clean,near mint condition
So what I do is sand and then clean with Naphtha
It's a great cleaner, degreaser....etc
But you need to make sure you go back one more time with clean rag to get the residue
I recall a couple jobs that I did that was really dirty
One of them I end up using TSP and pretty much had to give the doors a bath!
There were not that many doors ( maybe 8 or 10)
But I don't really like using those products
You're getting water in the wood and you need to make sure that you let them dry
And I mean fully dried, don't think that because it looks dry on the surface that means you good to go
It needs to dry deep into the wood
Refinishing doors that is damp can result in a bad experience!
The other job I did was also bad and a lot of doors and drawers but homeowners decided to replace them so I only had to deal with the cabinets and it wasn't as bad
So I sanded the face frames, cleaned with Naphtha and used a white vinyl primer to seal it
Usually if anything is going to react in a bad way it's going to show after you prime it
So pay good attention after priming
When it looks good, proceed with top coat
Good luck
4/29/21       #7: Kitchen cabinets repaint ...
Daniel Shafner Member
We clean with 50:50 ammonia & water. I prefer 1:10 Murphy's Oil Soap & water. In our pathetic state of CT, naphtha isn't available except by out of state, Hood Finishing Products, for example. After cleaning, we scuff sand with 240 cushioned abrasive. Filling is with 3M High Strength Hole Filler, a spackle type of material. That's leveled with 400 grit Abranet or 400 grit Uneeda H&L sandpaper, depending on what I have.
After scuffing, we shoot on a catalyzed pigmented vinyl primer. That gets scuffed with 320 or 400. Vinyl hates to be sanded. It corns on the sandpaper. Scuff at low speed or by hand, very light touch.
We spray onsite. We use conversion varnish. No painting.
    • Supergrit Abrasives
