RE: Hand-Applied Finishes
5/6/21
Kenneth
Are there hand-applied finishes to make grains of hardwoods (such as white oak, red oak, and maple) pop?
Also, are these finishes organic?
5/7/21       #3: RE: Hand-Applied Finishes ...
rich c
Isn't every finish applied with hands? What is your need for organic?
5/7/21       #4: RE: Hand-Applied Finishes ...
rich c
It would sure help if you ever responded to your organic posts.
5/7/21       #5: RE: Hand-Applied Finishes ...
rich c
5/7/21       #6: RE: Hand-Applied Finishes ...
Shellac is derived from resin excreted by insects. You can dissolve shellac flakes in grain alcohol you can distill at home with organic corn or barley. It will enhance the grain of wood beautifully. The down side is that it is easily marred by moisture, alcohol, and oils.
Technically every commercial finish is organic - meaning containing carbon. Certified organic is a food stuff designation and has no relevance to wood finishes.
5/11/21       #7: RE: Hand-Applied Finishes ...
Gary
I am assuming you are referring to a hand rubbed finish(French polish). Another alternative instead of shellac is 77 Lubricite which is a shellac based padding lacquer. It seems to be more durable than basic shellac and is what I have been using for years on wood that requires a beautiful hand applied finish.
