CV as a wall covering
6/16/21
Mark Member
In my very limited spare time I've been gutting out an old airstream camper. Once empty I planned on recovering the walls which is some kind of plastic shell, I've got a fair amount of tinted CV on hand as well as vinyl sealer primer left from a cabinet job where they switched colors. Has anyone ever used CV as a wall covering? pros/cons? temp ranges of the camper sitting outside -30F - 110F.
6/17/21       #2: CV as a wall covering ...
rich c
Aren't Airstreams made of aluminum? In that temp range there is going to be a ton of movement in the metal. I'd anticipate lots of CV cracking.
6/17/21       #3: CV as a wall covering ...
Mark
Yes, exterior is aluminum, insides is lined with some kind of plastic or vinyl skin, that’s what would be getting sprayed. I did this once on a different airstream but I sprayed with paint, I didn’t notice any cracking but I only had that one for a couple years.
6/18/21       #4: CV as a wall covering ...
Jim Clark Member
Does aluminum expand more than wood?
I've seen a lot of expansion in dining tables
with CV and not any cracking.
6/18/21       #5: CV as a wall covering ...
rich c
I've never seen a table as long as an Airstream. I've also never seen a table sitting in conditions that could go from -30 to 110.
6/18/21       #6: CV as a wall covering ...
rich c
The CV solvent may just melt that plastic or vinyl. Do a little sample before spraying.
6/19/21       #7: CV as a wall covering ...
mastercabman
I'm not saying that you can
But if you do decide to do it I would use a vinyl primer first
6/19/21       #8: CV as a wall covering ...
masterblaster
cv's are not known for their flexability hence the manufactures worry about dry film build. add in the temp range which is like the cycle tests they do in the lab, i would bet not a simple manufacture would be ok with its use on your project. use a 2k poly exterior finish with a alittle auto flex agent added and you'll be fine.
6/29/21       #9: CV as a wall covering ...
Matt
Don't do this to yourself. That CV is going to offgass in that Airstream for MONTHS. The odor will be unbearable.
In your shoes I'd suggest a product sold by Sherwin Williams called "Industrial precatalyzed epoxy", which is very user-friendly. It's a 1-part finish and behaves almost exactly like wall paint. Just roll or spray it on like you would latex.
It DOES have a stronger ammonia smell as it cures but that usually goes away overnight.
It remains flexible. I know, because my kids are peeling it off the bathroom sheetrock in pretty little strips.
