CV as opposed to 2K poly for tops
6/25/21
mastercabman
Hello all
I don't do a lot of finish on tops
I know that most businesses uses 2K poly on wood countertops
And I understand that 2K poly is a better product to use on vertical surface
I have been asked to build and finish a top for a job that I will be installing the cabinets
That section is called the TV wall so I assume it's going to be used as a piece of furniture
I really don't want to jump on trying out. 2K poly just yet(maybe someday if I get a lot of request!)
So my question is,how comfortable are you using a CV (pigmented or clear)on a top that is going to be used as a furniture?
6/25/21       #2: CV as opposed to 2K poly for tops ...
The big problem with using CV for table tops and counters is film thickness. Those surfaces take alot of abuse. CV is so thin that you could scratch through it easily. I would use anything other than CV simply for that reason.
6/25/21       #3: CV as opposed to 2K poly for tops ...
I use 2K poly on tops and counters because of the durability. CV scratches to easily.
6/25/21       #4: CV as opposed to 2K poly for tops ...
Bob Niemeyer  Member
2k PU runs circles around CV for tops that are going to be abused and used. The problem is most finishers don't know how to properly choose the correct type or how to use it. Ask lots of questions from your supplier tech rep.
6/26/21       #5: CV as opposed to 2K poly for tops ...
Thomas
Mastercabman,
If you want a "bullet proof" topcoat try using a 2K polyester. Super strong finish. You have to remember: the stronger the finish the harder to repair if need be. Even though CV is technically a "2K" product, it is at the bottom of the 2k line as far as strength. I am not familiar with any product stronger than 2K Polyester. We shoot a lot of 2K Polyurethane on aquarium products. It has held up well for saltwater as well as fresh water tanks. There is not much difference between shooting CV (which is a 2k or catalyzed product) and shooting 2k poly. The poly would be much stronger than the CV.
6/26/21       #6: CV as opposed to 2K poly for tops ...
mastercabman
Ok thanks
I am going to look into it
I do have some questions about 2K poly
I never used it before,I've sprayed some other form of poly but not 2K
If this job lands on me,can I use my spray equipment that I have now?
I mostly spray CV/pre-cat (solvent based)
Should I be concerned about contamination?
If I have to buy more equipment,I'm good with that but don't want to invest too much because I don't know how much work I'm going to get that will need a 2K finish
What type of sprayer will work good?
I will most likely use a 2K from MLC
I think they have
Arroyo
Coda
Polarion
Which one should I look into?
This coming job will be a top that will be painted to match the cabinets color
I will most likely use MDF for the deck and soft maple as the edge
Thanks again
6/26/21       #7: CV as opposed to 2K poly for tops ...
nicko
To answer your question of "how comfortable would you be using CV on a top that is going to be used for furniture?"
I would be very comfortable.
nicko
6/26/21       #8: CV as opposed to 2K poly for tops ...
Daniel Shafner Member
Arroyo is a waterbase finish. It's thick, 50 seconds through a Ford #4 cup. Maximum dry film build is 6 dry mils.
Then there's Coda vs Polarion. Polarion is more durable than Coda. For me, that says it a lot.
Both Coda and Polarion have similar specs, almost. Polarion has slightly more solids content.
6/26/21       #9: CV as opposed to 2K poly for tops ...
Never heard of a 2K polyester. Always thought they were 3K.
What's the brand and name?
6/26/21       #10: CV as opposed to 2K poly for tops ...
Chris
I spray 2 k urethane from Ilva.
I normally use a kremlin 10-14 AAA but I sometimes use a basic help gravity feed gun
6/27/21       #11: CV as opposed to 2K poly for tops ...
Thomas
Most suppliers sell the polyester finishes...ML Campbell, AkzoNobel, SW, Mohawk.
6/28/21       #12: CV as opposed to 2K poly for tops ...
Leo,
Are you thinking about Awlgrip paint? That’s a polyester based linear urethane paint that is always mixed with a lot of spray reducer. It’s still a 2K plus the reducer(not 3K) It’s the most bombproof finish ever primarily used on boats.
Then there is the typical 2K urethane that we all use. The polyester is similar to boatbuilding resin. The resin plus catalyst. That’s the finish they use on pianos.
6/29/21       #13: CV as opposed to 2K poly for tops ...
Masterblaster
Some companies add the cobalt at the plant zome don't. So it may be a cobalt, peroxide and thinner mix.
