Good method for orange peel prevention
7/14/21
Nick Cook Member
Website: http://kootenaicabinets.com
Hello,
We're going to an ML Campbell conversion varnish. This is over a water base white primer. It's been hot here, 100. Hot for North Idaho. My question is, oh and we're using Kremlin AAA set ups, is there a tip size and combination of reducers or thinners that will enable us to get one final coat of color(White in this case) over the base coats of primer? Is that wishful thinking? Also I'm getting some bridging that I don't like between the MDF flat panel and the stiles and rails.
We're using the TURINO post catalyzed Conversion Varnish.
7/14/21       #2: Good method for orange peel prevent ...
mastercabman
When it's too warm I use Flow Enhancer Slow Reducer 2(C163)
A 411-511 tip is just fine for Turino
7/17/21       #3: Good method for orange peel prevent ...
Our MLC tech guys are really good. Did you call them? What did they recommend? Keep in mind some guys in Phoenix deal with those conditions most of the year.
