Cherry
9/4/21
Charlie Moffett Member
I’m looking to do a lighter color stain on Cherry, is there a way to block the red to keep the color from being pink looking.? The factory cabinet companies call the color Cappuccino, I’ve seen several different ones at Lowe’s and Home Depot.
9/4/21       #2: Cherry ...
Mixing green dye into your stain will kill the red. Tread lightly.
9/5/21       #3: Cherry ...
I was wondering about that. There is probably a very fine line between blocking the red and turning it green. The dye seems like it would be more transparent also.
9/5/21       #4: Cherry ...
You can also spray the green dye as a toner to block the red. Then you can control it if you are patient. As the film dries it gets smaller amplifying the green dye. I learned my lesson with that using black dye. Looks great right after it's sprayed and flashed. But 20 minutes later it's darker.
If you can mix it in your stain it'll probably be more reliable. But I'll bet there will be a lot more testing involved to get to the right color.
9/6/21       #5: Cherry ...
Chemmy  Member
What exactly are you finishing Charlie, tables chairs kitchen cabs..??
9/6/21       #6: Cherry ...
I’m going to be finishing cabinet doors and end panels. My customer brought in a sample door from Lowe’s I think. She said she has seen this color called cappuccino several different places. I’m thinking if it’s on factory manufactured cabinets, it is probably sprayed stain through a finish line. It’s pretty transparent, and it doesn’t look like a wiping stain. I’m going to get some ML Campbell green dye and start testing.
    • Supergrit Abrasives
