Kem Aqua plus gravity feed
10/5/21
Hazeltree Member
So I have always sprayed with a Apollo quart cup gun through a Apollo turbine. I purchased a gravity feed Apollo gun to spray some cabinetry on site. Using sw Kem Aqua plus I kept getting small junk spots as if the finish was actually drying on the top and then coming off onto the surface. I switched over to my normal gun that I have always used and have had no such issues. Seeing as I have zero experience with gravity feed guns prior to this I was hoping someone may be able to give me a little insight into what is going on here. Thanks In advance
10/5/21       #2: Kem Aqua plus gravity feed ...
John Member
The bottom cup gun is pressurized, the gravity feed gun is not, except for gravity, so the needle needs to be larger to get the same flow unless you thin it. I had poor flow out and a gritty feel with KA+, even with my pressure assisted HVLP gun, until I started adding about 3 - 4% of General Finishes Extender to it. After I added the Extender it sprayed great.
John
10/5/21       #3: Kem Aqua plus gravity feed ...
Hazeltree Member
Thank you very much. That makes perfect sense
10/11/21       #4: Kem Aqua plus gravity feed ...
Garima
I am a new bee and probably doing a once in a life time project of cabinet painting. i purchased the kem aqua plus primer and semi gloss paint with high hopes of buying a gun and experimenting with spray painting but i am now chickening out and thinking of just doing a roll painting on cabinets w kem aqua plus. is that paint ok to roll with???? or is it ONLY made for spray painting?
doing this on oak. i will be sanding using liquid sander first and then apply primer. wondering if a 300 sander would be good enough post primer.
10/11/21       #5: Kem Aqua plus gravity feed ...
Hazeltree Member
I believe kem Aqua plus is strictly to be sprayed
10/12/21       #6: Kem Aqua plus gravity feed ...
John Member
The grain is going to show through on oak. If that's what you want, OK, but if you were hoping for a smooth finish you will be disappointed.
KA+ is a spray only product, but many waterbornes can be brushed or rolled if you add some of General Finishes' Extender to them. The addition of 3 - 6% by volume will extend the open time and allow the finish to flow out before it sets. This won't work with all waterbornes but it does for many. That said, you might be better served by switching to paint. SW's Emerald Urethane Trim Enamel goes on great with a brush or roller. Same with BM's Advance.
John
10/12/21       #7: Kem Aqua plus gravity feed ...
Al
I did a project with oak doors and drawer fronts. These were veneer slab doors and drawer fronts. I did not like the KA surfacer sprayed on it, came out pitted and blotchy.
I thinned it 5% with water and put it on with roller, I think 2 coats. Sprayed 1 coat KA plus white for finish coat. Grain shows through but that’s exactly what customer wanted. They came out really nice, I used the 6” foam rollers. I only use the KA plus with a pressure pot.
10/14/21       #8: Kem Aqua plus gravity feed ...
Garima
Thank you so much for the input. So I am returning the Kem Aqua plus cause I have still not managed to garner the courage & time to use spray gun.
So looking for options that are BEST for cabinet painting with rollers.
How is SW Emerald Urethane Trim Enamel? If i am sanding all surfaces well do i need to use a primer with that? If yes, which one?
10/16/21       #9: Kem Aqua plus gravity feed ...
John Member
Emerald Urethane Trim Enamel goes on great with a brush or foam roller. You can use a primer, or not, but I wouldn't it you want the grain to show. You may want to thin it 5 - 10%. Practice on scrap until you are confident.
John
