Automated spray system
11/12/21
Pierre Member
Hello all. I run a very small cabinet shop. We do almost everything in house including finishing.
We will be moving to a much larger building in the spring and will need to streamline the finishing. There will be plenty of space for a proper spray room.
As it is now either myself or one other guy sprays. Neither of us is very good or experienced at it and it's honestly the area that needs the most attention.
I've seen some automated spray systems out there but they look very large and expensive. I'd like to know if anyone has or has worked with something that will fit into a 3 man shop system and will not cost over $30,000.00.
We do roughly 6-8 kitchens a year and maybe another 8-10 built-in and odd cabinets. We will be looking to triple that output in the new building.
If I could find a career professional finisher that can swing between that and the shop side that would probably work. But we can't find anyone.
Nobody is good enough at it in my opinion and we do high end kitchens so it's an issue.
Any suggestions on either some automated spray systems or else something to make this work like it should?
We primarily use ML Campbell Arroyo waterborne products and have had much better luck with that than the Aqualente we used before if that matters. Any and all feedback is much appreciated!!!
11/14/21       #3: Automated spray system ...
You're planning on doing all flat panel finishing on the line, or assembled boxes? If you plan on replacing a human finisher, don't you need a robotic arm machine? If you are just going to do flat panels, can't you buy prefinished sheet goods?
11/14/21       #4: Automated spray system ...
Pierre Member
Rich
Cabinet doors and face frames mostly. I use prefinished plywood for boxes. And I don't know really what's practical and possible regarding Robots,machines etc. That's why this post.
11/14/21       #5: Automated spray system ...
Hen Bob Member
I would recommend to keep looking for a finisher. There are qualified people out there..
The automated lines are great if you have the volume. I've been shopping them myself and it seems to end up being a 160K-200K investment when its all done. It's not just the spraying machine, you need the sander/panel cleaner and everything else to make it efficient
11/18/21       #6: Automated spray system ...
Tom C
Pierre
You do not say the present set up you work with ?. Is it a couple cup guns, a pressure pot?
You're not the high volume for a flat line finish system. I have looked into it.
We are a 5-6 man 5K Sq ft shop doing 12-15 kitchens, dozens of vanities, wall units, mud rooms, millwork annually. Totally Flat Panel finishing.
Our set up is a 12 ft open Booth ,fan on a VFD. 3 Kremlins pumps,1 is primer,1 is clear 1 is pigmented.
A couple loose CAT Jaguar guns on 3M PPS for short runs ,one offs ,touch ups. All SW CV Solvent finishes.
We bought 1 CAT H2O pump bought to try out for Waterbase, Not yet there to go 100 % especially now that it is cold.....
Between Booth ,Pumps, Guns, Air dryer, Hafele Racks, Booth Dry fire system or sprinkler building set up, Permits !!-- You are @ 30K or more.
Do you need make up air ? I designed the heating system boiler to use external air so that when the booth is on - I am not drawing flue gases back in !
Hot water goes out to blowers. Do not use gas fired ceiling units unless you want to pass out from CO2 !-Back draft...
In 40 years of doing cabinet work, but 20 years of finishing , I learned the most when I had a "Truly Professional finisher" for 5 years. Good, fast and $$$ big bucks.
Finding one is like a needle in a hay stack. I am trying to get a Painter I know to come in ,says he is tired of ladders.
Now my foreman and myself do the stain jobs, With another guy and a helper do the prime/ paint jobs.
He knows all the technical end but does not want to be stuck in finishing all the time...
A lot to consider - Good Luck !
11/19/21       #7: Automated spray system ...
Pierre Member
Tom
We have a spray room that's cobbled together. New place will be more suitable. But we run a AAA CAT pump and cougar guns.
I have a cup gravity gun it don't know how to use it and the MLC rep honestly isn't much help there.
We spray ARROYO from MLC.
No explosion proof needed. Exhaust fan is just a 24" with a medium sized plenum blowing outside directly.
I'm not sure what makeup air is.
If I could find a career finisher I'd hire him and teach him to work in the shop in between sprays he's interested but as you said that's a hard find.
I do expect our volume of work to double or maybe more in the new building though.
This is indeed a tough but to crack because the finish is the most important part of all this and it's the area we need the most improvement in. Balls!
