Specks in black paint
11/14/21
Mark Member
I am having a very hard time getting a nice black matte finish to lay down without getting specks in the paint (conversion varnish)
I'm using an 04 tip in a Kremlin pump.
Any thoughts on what I'm doing wrong or I could better?
Thanks,
Mark
11/14/21       #2: Specks in black paint ...
Specks. I assume you mean white specks. So that might be dust falling on the surface while it's still wet. Clean the room better?
Or something else. More info please.
11/14/21       #3: Specks in black paint ...
masterblaster
tip is to small. move up to an 06 and put on a good box coat or 1 1/2 box. the specks should go away.
11/14/21       #4: Specks in black paint ...
You haven't figured out if it's a contamination issue or solvent or product problem? When I started doing black furniture, I kept an HVLP gravity gun just for black.
11/18/21       #5: Specks in black paint ...
Mark Member
Leo, the specks were not dust or particles that fell into the finish, they appeared immediately.
Rich, I don't believe it's a contamination or solvent issue either.
I am going to try an 06 tip. I was wondering if that may not have been part of the issue, that's why I brought up the size. Thank you for that masterblaster.
I will let you know how it turns out.
Mark
11/24/21       #6: Specks in black paint ...
Karla Gossling
Why does a small tip create white specks?
11/24/21       #7: Specks in black paint ...
Mark
Karla,
They were not white specks, they were the color of the black paint.
Mark
11/24/21       #8: Specks in black paint ...
Karla
Why does too small of a tip create any specks at all compared to a bigger tip?
