Clear over pigmented
12/2/21
Chris
Are any of you guys spraying clear overtop of your pigmented finishes(cv & 2k)? Is there a noticeable improvement in durability?
Do you scuff the pigmented topcoat before spraying clear? I’ve always wondered about this because I assume scuffing would leave scratches visible through the clear coat.. but how would you ensure proper adhesion without this step?
12/2/21       #2: Clear over pigmented ...
I've done it. Clears are much easier to tend to. If you get scratches later on it's easier to just spray another clear over it instead of trying to match colors.
And yes you need to scuff the coat unless you are spraying the clear within about 2 hours where it will still burn in. (MLC products for me).
12/3/21       #3: Clear over pigmented ...
Mastercabman
I've done it to
You do need to scuff sand and no it doesn't show when the clear goes on
Unless you scratch it hard but never had that problem
Like Leo said,it is a little easier to touch up any scratches with the clear
I kind of like doing it that way better
I've only done that way with clear over tinted primer
It works good
12/5/21       #4: Clear over pigmented ...
Jon Member
We shoot clear CV over darker colors that need to be mixed in clear base as they tend to be softer than colors mixed in white base. We usually have a clear CV sealer tinted. It is easier to sand. 2 coats sealer and one coat clear CV.
Acroma-Pro products for us.
12/6/21       #5: Clear over pigmented ...
Daniel Shafner Member
If you scuff your primer, your scratch pattern isn't seen in your clearcoat. Texture-wise, your scratch pattern can show, but not color if both coating types are sharing the same refractive index (the same physical principle why a diamond seems to "disappear" when in water).
12/9/21       #6: Clear over pigmented ...
Pdub Member
Be aware that the clear will alter the color slightly. Even "water whites" can do so. It's usually subtle so may not be a big deal unless you're going up against a matching surface.
If they're good, your supplier/ matcher can overcome this.
12/26/21       #7: Clear over pigmented ...
Dan
We use MLC Krystal over dark tinted Resisrant . They say it’s not needed but we definitely see the benefit, it wears much better
