getting purple walnut to brown
12/8/21
Matt Atkinson
Website: http://furnituredesignservices.com
What can I do to purple walnut to make it brown?
12/10/21       #2: getting purple walnut to brown ...
masterblaster
it depends on the final color needed. if light you'll be bleaching. if a strong dark color you may end up dye staining first as a base color.
12/10/21       #3: getting purple walnut to brown ...
Bleaching walnut has the chance of making the walnut have a greenish tint to it.
Or you might add some yellow dye to your clear to kill the purple.
12/11/21       #4: getting purple walnut to brown ...
"Brown" is a broad spectrum. On a color wheel, it shows adding red and a tiny bit of black would make brown. But there is chocolate brown, orange brown, yellow brown, etc......
12/11/21       #5: getting purple walnut to brown ...
You can also leave the finish sanded piece outdoors in direct sunlight for a couple of days and then dye it. Walnut takes very little time to change the base color.
12/11/21       #6: getting purple walnut to brown ...
Chemmy  Member
Best to let the walnut set until it's turned brown on it's own. If you have consistent lighting in your shop, hopefully florescent D-65 K, it should only take a few days or less for the blueish color to be gone. Just make sure all wood is exposed as evenly as possible. As Rich C stated, you can put it out in the sun also, depending on how much you have, this will work, but if a lot of sheet goods, personally, I prefer just letting it age inside.
