staining ebony
11/30/21
Jeff Member
I'll be using Macassar ebony to veneer a project, however I'm finding most veneer has too much contrast to it. I'm referring to what I imagine is the early- and late- annual, not the contrast between the heart and sap wood. I'm trying to match an existing piece, so I need the lighter stripes to be toned down. The existing piece isn't solid black, but has black and very dark brown stripes.
Are there any special considerations when staining and lacquering Macassar ebony? I've worked with what was formerly referred to as Gabon ebony, and it was tricky, requiring a solvent wipe-down before gluing, etc. Are aniline stains, water-based, oil-based, etc. better or worse? How about nitrocellulose lacquer vs. conversion varnish?
Can I provide any more info?
Thanks for the input.
12/11/21       #2: staining ebony ...
Chemmy  Member
What thickness is your veneer, how large is the object your applying it to, what kind of glue are you using, is it already applied or not.?
12/14/21       #3: staining ebony ...
Jeff
The project is essentially a box that's 16" x 24" x 18" tall and will be veneered on the top and all sides. The side-to-side corners will be radiused but the top-to-side corners will be square. No construction has been done yet.
The veneer will most likely be standard 1/42" raw wood (not paper-backed). I'm not sure what adhesive I'll be using. I've read that Titebond III works well, but I'm also considering using Unibond or some other catalyzed adhesive.
