help, table top badly reacting to precat.
1/14/22
Lowell A. Galumbeck
Website: http://Lowellsfurnitureservice.com
Refinishing a 1940 solid mahogany drop leaf table.Completely stripped and neutralized.Grain filled top and then started sealing.The entire base is normal with no issues.
The tops badly reacted like orange peel on steroids, then cleaned tops down resanded and washed with lacquer thinner and acetone.Same reaction happened again.
Third time applied coat of shellac and tried small test area, same crazy reaction.
Any suggestions, I'm using Chem Craft sealer and precat??
1/14/22       #2: help, table top badly reacting to p ...
Mastercabman
Just a tough
I would sand it down
Then clean it with Naphtha or mineral spirits
Then use a vinyl sealer
You can top coated with pre cat
1/14/22       #3: help, table top badly reacting to p ...
Is it orange peel or silicone contamination called fish eye? For fish eye you have to lay down some super dry coats of finish to seal it up. Super dry shellac coats are what I do with no sanding. Then try some super dry layers of precat. Layers that almost look like dust. Then lay on a coat that starts to look wet and very lightly sand that. Then you can put on wet coats. Be very careful not to exceed wet coat film thickness recommended by the supplier. You might get a recommendations to use fish-eye eliminator, but that can ruin your gun because fish eye eliminator has silicone in it to get material to flow. You take a chance of this happening again. Where ever you sanded that table must be cleaned very well to prevent contamination on your next project.
1/15/22       #4: help, table top badly reacting to p ...
Chemmy  Member
Hi Lowell, provide pictures please...tnx.!
1/15/22       #5: help, table top badly reacting to p ...
Try a coat of vinyl sealer first. Sounds like contamination, likely from Pledge.
