Problems painting mdf v solid wood.
1/24/22
Richard
We are spraying a large bookcase with conversion varnish and are running into a problem of junk getting into the finish, but its only on the mdf parts.
The solid wood doors are coming out fine, maybe a couple of nibs, but when it comes to the mdf shelves it looks like someone has thrown sand over them.
The spraybooth is clean, we mist water over the floor prior to spraying, in fact, we tried every trick we know including using a brand new cup gun and the same thing, perfect wood doors and anything made from mdf is terrible.
Any suggestions?
1/24/22       #2: Problems painting mdf v solid wood. ...
Mark B
Are you sure its not the MDF swelling from below?
1/24/22       #3: Problems painting mdf v solid wood. ...
Mike m
Have you tried putting liquid fabric softener into a pump sprayer mixed with water and spray that on the floor, along with the surface area where you are spraying the doors?
1/25/22       #4: Problems painting mdf v solid wood. ...
How many coats are you using. Cheaper brands of mdf sometimes get a rough surface after the first coat of primer. Typically, it will sand off and not come back.
1/25/22       #5: Problems painting mdf v solid wood. ...
Kevin Dunphy
Website: http://www.kdunphy.com/
Adam right all the dirt and dust in the pores come to the surface. It's because the clear coat fills the pores [ yes there are pouers in mdf] and dirt comes to the surface.
A long time ago I set up new airlines with a drier from a car rad what a difference all work is blown out before spraying.
1/25/22       #6: Problems painting mdf v solid wood. ...
Glen
We spray pigmented lacquer on MDF all the time. We use a lacquer undercoater and never have any issues.
1/25/22       #7: Problems painting mdf v solid wood. ...
Richard
Thank you for the responses.
It was the mdf fibers causing the issue. Due to supply issues, we used some ultralite mdf that we had in stock rather than the super refined, problem #1.
My finisher was putting a thin coat of primer, the fibers were swelling and then being sanded down as he prepared for the next coat. Each coat any exposed fibers were swelling again, and round and round we went.
1/26/22       #8: Problems painting mdf v solid wood. ...
In decades past, there was a technique called "whiskering". You took a barely damp cloth and wiped down the wood to swell any fibers that had not be cut off with sandpaper. Then you did one last pass with fine sandpaper. That made for a very smooth surface to lay the primer down.
1/26/22       #9: Problems painting mdf v solid wood. ...
Glen
We got some of that bad ultralight and it is like a ground paper instead of ground wood. I had to go to three suppliers to find the higher quality. The soft edge one is pure junk.
    • 2Sand
