Anyone using Mirka Deros instead of air sanders?
1/25/22
Matt
Currently we're using a mixture of Dynabrade and Mirka 5" air sanders and are quite happy with them, however we also need some more sanders to accommodate increased production.... and don't really want to put any more load on our air compressor.
Are the 110v Deros sanders a truly good production tool? In other words, does your team genuinely like using them, get good results, and do these things stand up to 8 hours of use daily the way a Dynabrade does?
We have downdraft tables, should we consider also getting the Deros with dust collection? Does the dust collection interfere with the functionality?
1/25/22       #2: Anyone using Mirka Deros instead of ...
Mark B
Kinda been covered extensively all around. On mass everything Ive read people are very happy with the Deros especially due to cost of operation.
I have 2 older Ceros in the shop that have been flawless (we were lucky and didnt have any of the transformer issues that many others had). When I wanted to add more I didnt want to leave the dynabrade envelope (Deros with transformer built on the back of the sander) so we went with Air Vantage for 2 more 6" sanders. Equally as impressive as at the time at least they offered the separate transformer form factor that keeps the sander pretty much identical to a dynabrade. To my knowledge Air Vantage and Surf Prep were the only manufacturers still offering the separate transformer style. Other bonus was at the time the 6" Air Vantage was only 319.00 which was a phenomenal deal. The dust pickup on the Air Vantage is great. Not as many selectable speed ranges but we just run the paddle trigger variable wide open so its just like a dynabrade (full speed control through the entire range with the paddle).
The only gripe I had with the Air Vantage is it has a safety time out feature on the paddle where if the sander sits for 5 minutes it times out so you dont in advertently hit the paddle or flip the sander over. So after the five minutes the indicator light on the back will be flashing and you just have to hit the speed up button and its back on. Irritated me initially but zero issue now.
Id imagine when you start implementing the DC sanders as your dynabrades age out you wont replace them. The cost of generating all that air and the noise is something I will never miss.
1/25/22       #3: Anyone using Mirka Deros instead of ...
I'm still running my Ceros and currently added a Deos for the finish room. Both are great sanders. Aggressive and fine enough to go straight to finish for stain.
I find the slightly larger and bulkier size of the Deros less attractive than the Ceros. But the performance is just the same. A bit less maneuverable because of the slightly larger size.
Well worth not having to be attached to a compressor.
2/1/22       #4: Anyone using Mirka Deros instead of ...
Dave Edgerton  Member
2 ceros running for 8 years flat out. 1 new deros running for 1 year flat out 6 days a week. Currently all 3 running all day. Changed a couple of bearings. Our 4 dynabrade sit on a shelf.
2/2/22       #6: Anyone using Mirka Deros instead of ...
Matt
Gentlemen this has been helpful information, and I'll look into the Air Vantage sanders, I was unfamiliar with them. Thank you!
