New O7 Spray Tip Clogging
2/23/22
Michael R Member
I purchased and in the past two days have been using C.A. Technologies Air Assisted Airless (AAA) Tip 407 (36-407) After about 5 to 10 minutes of spraying with this new 07 orifice the tip starts clogging from the inside. I'm using white pigment Kem Aqua plus. I thought the tip was clogging from the outside so I tried cleaning it a couple of times with a bristle brush using water then lacquer thinner but that did not do the trick. I actually had to pull tip off and put it in a plastic bottle with lacquer thinner with light shaking. That unclogged the spray tip but after using it again for 5 to 10 minutes clogging occurred again.
Does anyone have any remedies to prevent this?
I was using the 09 tip without any clogging problems so I wanted to try something smaller to prevent occasional pinholes. When the 07 tip is not clogging it lays down a beautiful finish so I like to find a way if possible for it not to clog without thinning.
Using 20 - 25 atomization, 30 PSI.
2/23/22       #2: New O7 Spray Tip Clogging ...
Mastercabman
07 is too small to spray that type of finish
I have a 411 on mine and spray solvent based finish
The pinholes you talking about is also known as micro bubbles
I could be wrong about this but usually it's because fluid pressure is too high
Maybe someone else can help you out with more experience with waterborne finish
2/23/22       #3: New O7 Spray Tip Clogging ...
Do you have a mesh screen O ring between the tip and the gun? Or are you running just a normal O ring?
2/24/22       #4: New O7 Spray Tip Clogging ...
Michael R Member
Leo G, no I don't have a screen O-ring in the tip.
2/24/22       #5: New O7 Spray Tip Clogging ...
or
129-609-901
MICROSCREEN,QTY 10,140 MESH
or
CA Technologies 36-100-10 AAA Micro Tip Filter O-Rings, 100 mesh, 10-Pack
2/24/22       #6: New O7 Spray Tip Clogging ...
Michael R Member
Leo G, hopefully that does the trick.
2/24/22       #7: New O7 Spray Tip Clogging ...
Each screen usually last me months. You do have to take them out and scrub them with a brush and blow them out. The toughest thing is getting them out. I have a pair of tweezers that I ground a point on for getting hairs out of my finishes. Usually that will get them out. I suppose an awl would do the same thing. But I use the tweezers.
Between the screen mesh at the bottom of the gun and the tip mesh O ring I never have issues. Haven't filtered any of my finishes in ages. Just pour it in and go.
I suppose that might be MLC, I've heard other finishes have lots of crap in them and have to be filtered.
Good luck and I hope it helps.
2/24/22       #8: New O7 Spray Tip Clogging ...
Michael R Member
Leo G, I have the O ring filters in my parts storage but a couple of years ago I got in the habit of not using them. I will now because I really like this new 07 tip. I can use my set of dental picks to remove them.
This will be the last time that I will be using Kem Aqua plus. I'm only using it now because of doing a matchup new trash can pull-out cabinet that will go up against an existing cabinet. Even though we knew the color we still had to tweak it.
I'm going to start using Envirolak water-based products. Hopefully, this will be my go-to finish from now on. I just brought 5 gallons of Envirolak EL 100 which are there warm clear in the 30 sheen. Hopefully, this does it and I won't have to go back to Kem Aqua plus.
