Skinning
2/26/22
dr Member
Anybody has a trick on how to prevent skinning when a can of varnish has been opened? I try the new can of Bloxygen which is junk, the old one was much better.
2/26/22       #2: Skinning ...
My super secret is to not buy more than I need. I can't remember the last time I had half a quart of anything sitting around long. Is your business that slow?
2/26/22       #3: Skinning ...
dr Member
Rich,
Business is not slow, what is slow is building a 40' yachts.
2/26/22       #4: Skinning ...
Chemmy  Member
Long before inert gasses became the thing, we used generic marbles to put in the can that brought the volume of the can up to the tip top of the inside rim. Then placed some food rap over that and hammered the lid shut.!!
Skins can't form when the can stays completely filled, and the marbles, or other heavier than than coating type objects, can be used to do this, like SS bearings of any size etc.
When the can gets to the point where the marbles are equal or close to equal, you just buy smaller cans to start the process over.
The best part is the marbles/ bearings/etc. Will last forever, A one time purchase, and can be easily cleaned with solvents and dried, and kept ready for their next use.!!
PS: use disposable cups to remove the amount you want to use, then add more marbles as necessary.
2/27/22       #5: Skinning ...
Mark B
We have light metal fab in the shop as well and have Argon and CO2 mix gas bottles for mig/tig and I just top off cans that wont see use for a while with Argon. Kind of a PITA but you could order a case or two of empty quart cans and box down your partial gallons into quarts.
If its something you deal with regularly I'd just head to your local industrial gas supplier and buy a small cylinder of Argon and a regulator. I use the Argon in everything from finishes to wood glue when needed.
Buying only what you need is a great concept but it rarely works perfectly across the board.
2/27/22       #6: Skinning ...
dr Member
Good tips, I may try the Argon. Thanks
2/28/22       #7: Skinning ...
masterblaster
if you are talking smaller qty's you can use a mason jar/lid and pull a vacuum on it. works well with 2k poly hardeners or anything that one opened don't last long. you can use a pressure pot to pull the vac if you have a vac bag set up or use a household seal a meal type with the lid sealing attachment.
3/1/22       #9: Skinning ...
Mitch Suber Member
Website: http://Suber custom shutters.com
With oil based products, I will often lightly pour a small amount of mineral spirits over the top of the varnish, so that an 1/8” or so of the mineral spirits sits on top of the varnish. Mineral Spirits is lighter than the varnish, the idea being the layer prevents the air in the can contacting the varnish. Next use, you just stir it in. Too much though, can over-thin the varnish, but usually it helps offset the varnish getting too thick with use. It seems to help.
3/1/22       #10: Skinning ...
Bob Niemeyer  Member
Why they pull the Bloxygen response? He was dead on with his response. There was not any "misinformation" and other vendors have responded to posts about their products here before.
Simple solution, remove the oxygen from oxygen reactive products and they last longer.
3/1/22       #11: Skinning ...
Steven Zawalick  Member
Website: http://www.bloxygen.com
The goal here is to eliminate damage from oxygen or moisture during storage. Bloxygen provides a simple and portable way to do this while using the original container with the original label.
The original poster had a problem with a specific finish. Over the 20 years of making and selling this product, we have found only three sources of problems:
1. Not Enough Gas Used: The entire storage container must be purged. You cannot use too much gas.
2. Slow Lid Seal / bad seal: Once the container is purged, the lid must be immediately sealed into place. Make sure that the lid is spotless and dent free to create an airtight seal.
3. Bad Finish: Once oil-based finishes absorb oxygen and skin over or gel, they will continue to have problems during storage. These finishes will never be the same. Start with NEW finish and use Bloxygen each and every time it's stored.
It sounds to me like his finish was exposed to oxygen or moisture and it has begun to cure in the container. This is unfortunate and cannot be reversed. Care must be taken to prevent exposing the finish to the atmosphere.
There are more details on our FAQ page (link below) and in the instructions I've attached.
I'm happy to help in any way. I hope this post does not get deleted. I'm just trying to help here.
Thank you all,
Steven Zawalick, Owner
Bloxygen_Instructions_2021.pdf
http://www.bloxygen.com/frequently-asked-questions.html
3/6/22       #12: Skinning ...
JeffA
I have cut a circle on cardboard using the lid of the can as a template. Then placed the cut out on the surface of the paint inside the can. It keeps the air off the surface but it doesn't work forever. May be a month or 2.
3/7/22       #13: Skinning ...
dr Member
Steven,
This is how Bloxygen works.
View higher quality, full size image (591 X 443)
3/7/22       #14: Skinning ...
Well I certainly don't like to see that and have spent thousands of hours and hundreds of thousands of dollars to deliver an effective tool to prevent that. Bloxygen works, but it takes special care to be effective. That's MAJOR oxygen damage. It looks like that finish was exposed to oxygen for a long time, sealed without purging, or perhaps was damaged by exposure to heat. As I said earlier, there are only three problems we've ever seen:
It looks like this finish was left open for a long time or perhaps finish from a secondary container was returned to the primary.
Our instruction manual is good and is here:
http://nebula.wsimg.com/7265e7cd47932371439c31d9cfd51a78?AccessKeyId=CB3A0C59E36B3
4210C41&disposition=0&alloworigin=1
Our Best Practices Video is here:
https://youtu.be/MlyzF6lC2PI
I'm very sorry this did not work for these leftovers. I'm happy to send you a replacement can of Bloxygen. We make it here in the USA and stand behind it. Please send me your address. I'm at IronWood.Designs@pobox.com.
3/7/22       #15: Skinning ...
dr Member
Steven,
Don't worry about a replacement can. The picture was taken a week after it was sealed with Bloxygen and the can was a 1/4 full. Let's put to rest this, I am going with Argon.
3/7/22       #16: Skinning ...
Bob Niemeyer  Member
Well I am going to speak up here and say Bloxyen does work when used as directed. I use lots of different Isocyanate catalysts
and they last years not months. Just used one today.
But it will not reverse a product that is starting to "kick off" due to not being protected.
It has saved me plenty of money over the decades.
Just to let you know nobody asked me to post this response, I just believe in the product and it has always worked for me.
    • Supergrit Abrasives
