Can A polyurethane Finish Be repaired
3/5/22
howard Member
Website: http://woodcontours.net
I am going to put an oil poly finish over a walnut kitchen table. I have heard from some that it cannot be repaired which doesn't seem right to me. In the case of surface scratches, why couldn't it be sanded back and recoated since the sanding scratches will give the mechanical bond? Appreciate your help with this.
3/5/22       #2: Can A polyurethane Finish Be repair ...
Clean it off, scuff sand it and apply you new poly. Just make sure oil over oil, water over water.
Otherwise the floor refinishers would have to strip to wood each refinish.
3/5/22       #3: Can A polyurethane Finish Be repair ...
Mark B
I think what you will find alot when repairs are spoken of is a spot repair being difficult or impossible to blend. A table getting scratched or worn and being scuffed back and re-coated is not really a repair.
3/5/22       #4: Can A polyurethane Finish Be repair ...
Mark B has it right. Once you start to wood(removing some finish back to bare wood) a finish, you can see witness lines where the wood transitions to the old finish.
Different coatings look different when you do this. You are correct that the mechanical bond will be fine.
Poly in particular vs shellac, varnish, or laquer tends to give you the halo effect around the bare wood.
I believe it's because poly is truly liquid plastic. It will not stick to itself without sanding. It tends to be a film finish and doesn't wet the wood as well as the other finishes I mentioned.
Your plan will work. Lower your expectations on the aesthetics.
