RE: Natural Organic Oil Finishes
3/18/22
Ken Member
Is there any natural type of organic oils that could be used to bring out all the “flavors” of the wood, and could also be used in multi-applications as a permanent type of finish, or can a wax finish be used as a final finish?
3/19/22       #2: RE: Natural Organic Oil Finishes ...
Permanent finish for what? A dining table, no. A jewelry box, probably. Kitchen cabinets, definitely not! Natural oils will never cure, but will get dry over time. This can take a month for some oils.
3/19/22       #3: RE: Natural Organic Oil Finishes ...
Chemmy  Member
Polymerized tung oil, can be used on furniture, but is not food safe. food safe mineral oil is what's used for things like cutting boards. Both will need to be renewed by further applications as needed.
As RichC noted, it depends on what it is your applying the oil to.? Personally I prefer shellac.!
3/24/22       #4: RE: Natural Organic Oil Finishes ...
John Member
Look at Rubio Monocoat and Osmo Polyox. Both are hardwax oils made with natural oils and resins. RM is zero VOC. It is amazingly durable with just one coat. Osmo requires two coats. I know, can't be true and I didn't believe it either until I tried it. And it's stupid simple to repair if/when needed. Just clean, scuff sand the damaged area, and wipe on some more. It only absorbs into raw wood so there is no overlap with the already finished area. Another one of the too good to be true statements - until you try it yourself.
RM is available on in satin. Omso Polyox comes in satin and gloss, I believe.
John
3/26/22       #5: RE: Natural Organic Oil Finishes ...
Ed Austin
All the designers in my area are hot on the Rubio .
Lots of videos out showing application methods.
Osmo is available in matte, and I think the
Osmo top oil is food grade for countertops.
Ed
