Finishing over UV-cured, acrylated epoxy,
3/28/22
Jay J Knobbe Member
Good Morning,
We are a interior design company. Our task at hand is finishing, assembly and installation of a 11' long built in unit for a client. Cabinets on the bottom, shelves on top. The components are RTA maple ply with UV-cured, acrylated epoxy finish. Everything except the cabinet interior needs to be scuff sanded and a WB finish applied. We were hoping to scuff sand w/180g trying not to break through the finish then go directly to top coat but that may not give adequate adhesion. Should we use a bonding primer prior to top coat? If so do you have a recommendation? The painter is also struggling with getting a good scuff since the finish is amazingly hard. Thoughts about that would also be appreciated. We are in the USA, midwest.
3/30/22       #2: Finishing over UV-cured, acrylated ...
Scuff, prime and paint. As you have discovered - UV coating will destroy sandpaper quickly. Tell him to get a box of paper and be prepared to use it. I figure that you get about 2 sq ft of scuffing done with a 5" RO sander before it stops working.
Maybe the newer ceramic sandpaper will last longer. Doesn't matter, it'll burn that up too.
3/31/22       #3: Finishing over UV-cured, acrylated ...
Many of us including Leo use a UV cured maple plywood for our cabinet interiors. Sometimes we have to paint it. As Leo noted it is very hard. We know exactly what it is and what products will stick to it.
You have zero experience with your UV substrate and don't know if your WB(they are all different) will bond well to it.
The industry typically uses Zinsser BIN primer as the primer/bond coat on hard to bond or sketchy surfaces. It's shellac/alcohol based and generally compatible with most finishes & substrates. I always say shellac sticks to everything and everything sticks to shellac. It's actually the best primer for waterborne products.
4/1/22       #4: Finishing over UV-cured, acrylated ...
Jay J Knobbe Member
Thank you for your response. Prior to today I did my own test with a variety of WB primers from Benjamin Moore and Zinsser. The best was BIN shellac. Passed adhesion tests (criss cross razor cuts and tape pull) and I couldn't scrape it off no matter how hard I tried. 2nd was Zinsser SmartPrime. It also passed the adhesion test and scrape test but as we all know BIN is a harder albeit more brittle surface. As they say, BIN for the win!
4/2/22       #5: Finishing over UV-cured, acrylated ...
I learned something new about BIN recently. I spilled some on someone else's concrete driveway. I was concerned that if I used alcohol it would simply reactivate/reduce it and spread it around making the spill problem worse.
I read online that ammonia works as well. I haven't read the label on a can of BIN in a couple of decades so they must have added since then.
Sure enough ammonia chews up the BIN, but it does it more in a detergent way. I was able to scrub the concrete with a few bottles of ammonia and wash it off with water.
