Conversion Varnish Outgassing
4/6/22
howard Member
Website: http://woodcontours.net
Just put down 3 coats Mohawk CV on table top. Went down great mixed to correct proportions and all booth conditions were to proper temp and humidity. For those that have used CV, how long does it take to outgas and become smell free? There's a slight "plastic smell" and the work was done 3 days ago. First two coats straight from the can, last coat cut 5% with reducer/retarder. Thanks
4/6/22       #2: Conversion Varnish Outgassing ...
duster
We use MLC conversion varnishes, and they take about a month to off gas completely. In a warm, well ventilated room, it does go quicker.
4/7/22       #3: Conversion Varnish Outgassing ...
21-30 days is average for a post cat. Stick it in a room and crank the heat as high a 110ºF for a few hours. That'll hasten the curing substantially.
4/7/22       #4: Conversion Varnish Outgassing ...
Depends on the recoat schedule. How long between coats? Your make up air is conditioned?
4/7/22       #5: Conversion Varnish Outgassing ...
Looked up the product sheet. 72 degrees and 35% humidity can be tough to do in the spring. The sheet also mentions only 2 coats and total dry film cannot exceed 4 mils.
4/10/22       #6: Conversion Varnish Outgassing ...
The can specs are for ideal spraying. It has nothing to do with curing. As Leo noted raising the temp will make it cure faster. I agree with the 3-4 weeks as others have mentioned.
That said I've opened a drawer cabinet about 4 months after a new construction install. No one had ever opened it. Still had that cv stench. Kinda reminded me of how fibreglass boats smell of styrene for years.
4/10/22       #7: Conversion Varnish Outgassing ...
Temperature has nothing to do with curing?
4/10/22       #8: Conversion Varnish Outgassing ...
Kevin Dunphy
Website: http://www.kdunphy.com/
That's the thing the curing never stops because acid is used so there might not be a smell but there are gases being released.
Same with particleboard off-gases. Most particleboard contains formaldehyde; a potent chemical.
The nose test doesn't work
But none seem to care but if I had a grandson none of the above would be going in his house, come to think of it that's what I did when I did my son's house.
It's a serious problem for us as workers
4/14/22       #9: Conversion Varnish Outgassing ...
Adam C
Mohawk Is better than Campbells, mohawk is about a month, duravar is 6 months or more, I have found the best stuff is Canadian, I am good in about a week without stinking out the clients.
4/28/22       #10: Conversion Varnish Outgassing ...
DannyB
The curing definitely stops, this is chemistry, not magic.
Eventually, every molecule that can pair/react has reacted.
This varies per-manufacturer/formulation, but 6 months is usually the absolute 100% limit you would find.
Most are closer to a month or less.
    • Supergrit Abrasives
