Painting Natural Birch
4/26/22
Nick Cook Member
Website: http://kootenaicabinets.com
Hello,
We typically use PG Beech for our painted solid wood parts. Does anyone have any negatives about painting Natural Birch wood?
4/26/22       #2: Painting Natural Birch ...
You'll need a good primer to cover the dark heartwood next to cream colored sapwood.
4/26/22       #3: Painting Natural Birch ...
Kinda grainy. Why not Maple?
4/27/22       #4: Painting Natural Birch ...
Nick Cook Member
Thanks for the input, the reason I was considering the Birch was one of our suppliers had a bunch at a good price. I need a small amount to make some legs for a vanity and he offered what he had that he was trying to move at a cheap price, so I thought I could use it for paint grade fillers and light rail etc on frameless jobs. So Leo, it's kind of grainy? Sounds like a hassle.
4/27/22       #5: Painting Natural Birch ...
If I'm not mistaken I thought Beech was a bit on the grainy side too. Isn't it like a mild version of Oak?
If you can handle the Beech you might be able to do the Birch. Get a stick and try to paint it and see how it works for you. That's what I would do if I was offered a good price on something that I was painting. If it doesn't work you're out $50 of materials and time. If it does you can save with the deal your getting on the Birch.
4/27/22       #6: Painting Natural Birch ...
Nick Cook Member
Yeah, I think I'll try it. The beech is nice for painting, even grain, way better than poplar and really on par with maple. Have not painted birch though.
4/27/22       #7: Painting Natural Birch ...
One of the caveats with birch is that the wood can have some pretty severe grain reversals in some trees. That makes the grain chippy as the birch is a little more brittle than your other choices. Painting is not the hard part of working birch.
4/27/22       #8: Painting Natural Birch ...
I agree with Rich. Once properly milled it should paint just like maple. The trick is not having it tear out when running it thru the jointer & planer. If you've got insert tooling for your jointer, planer, and shaper(sizing). I would use birch instead of soft maple if its at a significantly lower price point.
Soft maple has plenty of dark spots. We've used MLC waterborne & solvent based primers for 30 years and never had a problem with bleed through.
The key is you won't have any problems milling soft maple, you probably will with birch.
4/27/22       #9: Painting Natural Birch ...
Nick Cook Member
Ok. We do have the machinery that should be fine for milling so I'm going to give it a try. We also use the MLC waterborne primer and like it. Thanks
