Original fabulon gloss floor finish
5/13/22
Lynn Taylor
I need a gallon or even half a gallon!. Apparently this is no longer made?. But someone has to have some someplace.! It is smelly but blends in easily for repairs and worn out areas. It's not Poly!. It's a straight lacquer. Please help me find some leftover stock! Please!
5/13/22       #2: Original fabulon gloss floor finish ...
shenendoah
Try google...
It is a Canadian made polyurethane ( sorry ).
There are dealers. Hunt a bit.
5/13/22       #3: Original fabulon gloss floor finish ...
What was different about the lacquer that other lacquers don't have?
5/13/22       #4: Original fabulon gloss floor finish ...
If the wood and finish is old, new any kind of lacquer won't match an old yellowed finish anyway.
5/14/22       #5: Original fabulon gloss floor finish ...
Pete Anderson
Website: http://petesfloors.wordpress.com
Fabulous is not a lacquer based finish. It is an oil modified poly-urethane. It darkens more than some of the polys I think because it has more linseed oil ratio and linseed oil tends to darken over time. An older Fabulous coated floor looks like a floor that has been stained a light brown then coated with a different poly, like DuraSeal, that doesn't get so dark over time.
If you are thinking lacquer based finish then you may be thinking of Deft, which is a brushable lacquer.
5/14/22       #6: Original fabulon gloss floor finish ...
Lynn Taylor
Thanks for everyone that responded. I need some to touch up some areas. It blends in so beautifully. I have used it on my floors for over 50 years. Mine does not say it is Poly. I would be worried that a Poly would not be compatible. Yes deft is much the same but I don't think it would hold up on floors.guess I will be forced to try something new!
5/14/22       #7: Original fabulon gloss floor finish ...
There are a lot better choices for lacquer than Deft.
    • 2Sand
