top coat of Glaze
6/6/22
junior
I am having trouble with top coat reacting to the heavy Glaze. currently i am use MLC vintage Glaze color is lamp Black. top coat is Sherwin Williams Sherwood CV. I am getting wrinkles and top coat peeling. I am allowing 1-8 hrs for glaze to dry not sure what could be the problem.
6/6/22       #2: top coat of Glaze ...
If it's heavy glaze as you said, 1 hour is ridiculously early to top coat. If it's humid, then the same things go for 8 hours.
6/6/22       #3: top coat of Glaze ...
I looked up the information sheet and it said you have to be done within 12 hours of the first application of sealer or base coat application. What sealer or pigmented base coat are you using before the glaze? Since it's called an alkyd glaze, it must have some resin in it to make it more like a varnish and hence the fast setup.
https://distributorserviceinc.com/PDF/Vintage%20Alkyd%20Glaze-PI.pdf
6/6/22       #4: top coat of Glaze ...
Leo G
Pretty sure the vintage glaze needs to be sandwiched in between layers of vinyl sealer. Apply your stain, then vinyl sealer, then glaze then vinyl sealer then topcoat.
6/7/22       #5: top coat of Glaze ...
Mastercabman
Technically,you don't have to"sandwich" the glaze with vinyl sealer you can top coated with CV
However the OP states that he's using a different brand of CV so maybe a good idea of using a vinyl sealer before top coat?
Junior,
Can you give us your schedule of finish for that project?
Maybe something else is happening during the process?
12/12/22       #7: top coat of Glaze ...
Jon W Member
If you are leaving the glaze on thick and not scuff sanding before top-coating, then it is possible that the acid catalyst is reacting with the alkyd resins in the glaze. A vinyl sealer coat after the glaze may eliminate this issue. If you have a thick layer of glaze, then the cv, which is mechanically bonded will have nothing to grip on to as it just melts the glaze and starts to dry over top a wet glaze layer that is reactivated by the CV solvents and possibly eaten away by the acid.
