How do you like your walnut?
7/6/22
Mastercabman
Hello all
Just trying to get some feedback on how some of you like to finish walnut
I am building a range hood that is simply a box with grooves to mimic shiplap
It will be painted in a grayish color to match the cabinets
At the bottom I will be adding a 5" tall band out of walnut
That will wrap sides and front
I was just planning on putting a clear finish like MLC Krystal
But I'm wondering if there's something else I could add to the walnut that would make it interesting
I don't work with walnut that much
So do you use something to make the walnut pop?
Stain?
What's your favorite?!
7/6/22       #2: How do you like your walnut? ...
Leo G
I always stain Walnut with a American Walnut stain. Not sure if it's a copy but I get it at Atlantic Plywood which uses MLC Woodsong II stains. I usually mixed the stain 50-50 with the stain base so it's not darkening. Keeps the Walnut from lightening over time as it normally does if you just clear coat it.
7/7/22       #3: How do you like your walnut? ...
Im similar to Leo.. A diluted Walnut or Dark Walnut stain and then clear. If you leave it raw with just clear depending on the Walnut and exposure it may just go silver-ish over time. Some does some doesnt, steamed Walnut in my opinion always needs stain.
7/9/22       #4: How do you like your walnut? ...
Denny J
I agree with using a dark walnut stain to even out the color
7/9/22       #5: How do you like your walnut? ...
Mastercabman
Thank you for the feedback
I'm going to check with the designer and see what she like best
Maybe she likes the lighter shade of walnut
One thing I hate about small jobs is that if I need a little bit of stain,I have to get a whole gallon
I just can't understand why not qt size?
7/9/22       #6: How do you like your walnut? ...
Depends on who your pulling from. Sherwin BAC and ML Campbell here will mix quarts. But we wind up in the same boat all the time if we are borderline. We have partial gallons out the yin yang from jobs that needed a quart and a half.
As sucky as it is you can often get away with quarts from sherwin non/bac in a pinch but they will be oil and not solvent stain.
12/31/22       #7: How do you like your walnut? ...
Chris Payne
Try using Minwax Golden Oak it really makes the Walnut looks good been using this for many years.
    • 2Sand
