Gravity gun for cv
7/16/22
Travis Alfrey
I spray ml Campbell post cat cv. My main systems are kremlin aaa. Looking for a very good gravity gun for spraying the one off stuff. Primer color and clear. Tired of having to mix up enough cv to feed the airmix for one door. Would a Fuji turbine system be better??
7/16/22       #2: Gravity gun for cv ...
Mastercabman
I totally understand!
I'm a big fan of CA Technologies
I have the jaguar gravity feed with the 3M PPS
I got the package deal with several tip/nozzle sizes
I've never been happy with turbine sprayers
7/17/22       #3: Gravity gun for cv ...
Jim b Member
Have you used the newer cat x gun.I am also looking for gravity gun for same purpose.I have kremlin and cat pumps.I am leaning towards that?,jim
7/17/22       #4: Gravity gun for cv ...
Mastercabman
Jim
The CAT X are great spray guns
I don't own one but used one during one of my classes
Those spray guns does an excellent job on the finish
Make sure you have a decent size compressor
The X does use 11-13 cfm(I think)
7/21/22       #5: Gravity gun for cv ...
CraigM
I have a few SATA 100 B RP guns set up with adapters for 3M PPS 2.0 cups that work really well for samples and small one off pieces. The RP version eats about 10 CFM and the HVLP eats about 12 CFM.
12/21/22       #6: Gravity gun for cv ...
Nick Sinderson
I have a couple of Sata 2000Bs both set-up with 1.4 needles/nozzles that l spray CV & 2K poly with. Fantastic spray guns; very fine and even atomization and durability.
