Hopper for kremlin
7/28/22
Travis Alfrey
I have always had the intake tubes for all of my airmix pumps. Now I am spraying post cat I was thinking about using a hopper instead of the intake tube. Thoughts?? Anyone know where I can get one?? Do I have to use one from kremlin or can I use another brand hopper
7/28/22       #2: Hopper for kremlin ...
Mastercabman
I wouldn't bother
I got one when I purchased my CAT pump
Used it a couple of times and put it away
I don't find them any benefits from a pick up tube
I don't know about your Kremlin but my CAT will suck up pretty much all material
You also end up spending more time an more lacquer thinner to clean the hopper
Some people complains about wanting to use the pump to spray a small amount of finish(like a door or a drawer front)
For me,if I have a very small job to do,I just use a gravity feed gun with 3M pps cup
Why bother setting up a pump just for a quickie?
7/28/22       #3: Hopper for kremlin ...
herb johnson
buy a used kremlin siphon hose so you get the kremlin fitting then shorten the hose up, and stick in a 1/4'' stainless pipe with hose clamp. save your money and do it this way and use a one gallon or quart can. custom length siphon hose easy and cheap
good luck herb j.
11/17/22       #4: Hopper for kremlin ...
Nick Sinderson
I use the hopper with my 10c18. It wasn't the plan...kremlin sent the hopper with the pump instead a pick-up tube, and since it took 3 months to get the pump and l didn't want another 6 weeks so l used it. I've gotten use to it and like it. Clean-up is quick and it uses very little solvent to clean it. That said it only holds between 2-3 quarts so there is more time spent loading the hopper but l find that to be no big deal.
