Safety with 2k poly waterborne
8/9/22
Al
I’ve read about the safety issues with 2k poly. I have supplied air respirator so have that covered. I’m asking about clothing protection. If wearing tyvek suit in paint booth and then want you to work in shop do you remove suit or just leave it on? Most times I spray some parts and then come back an hour or so later. So I’m thinking suit gets removed and only worn when painting. Remove suit before removing respirator? The companies that sell 2k products really don’t elaborate on these issues. I think most guys would get of booth remove respirator and then take off suit. This would leave you exposed to the overspray on your suit.
Would appreciate what most are doing.
Thanks,
Al
8/9/22       #2: Safety with 2k poly waterborne ...
I think the response that you will get from most will be you need to protect everything mucous membrane period. Mouth, nose, eyeballs, I guess that would include your backside/frontside even though those are not exposed and exit only.. The other one youll hear is if you can smell it in your shop its there. Pretty hard when I walk into one of our suppliers that is an auto body supplier (PPG top of the line) and the entire place smells of solvent and the counter staff say they are nose blind to pretty much anything.
In my personal opinion waterborne 2K flashes off so fast if you just spend a bit of time in the booth getting wrapped up, etc, and take off your hood and suit in decent airflow outside the booth I wouldnt worry about it too much but I'll likely get chopped to bits for that. I spray a all WB and a fair amount of 2K. Gloves during the whole mix and to the booth, full protection spraying, and Im usually doing a few little things for a few minutes once out. Good airflow in the booth there shouldnt be much in the air when you come out but Ive never passed the "cant smell it' test.
8/12/22       #3: Safety with 2k poly waterborne ...
The really toxic chemical in 2k wb & solvent poly is the isocyanate hardener. It's only dangerous if you aerosolise it and then breathe it. Once it's deposited on a surface like your gloves or tyvek suit it is no longer dangerous. You can use regular respirator filters when brushing/rolling those same products. The solvents have the same hazard level as any other solvent finish.
Its common for people to roll & tip(brush) entire boats with Awlgrip. They use regular respirators not forced air.
8/16/22       #4: Safety with 2k poly waterborne ...
Al
Thanks to you both. About 2 minutes after I posted this the Chemcraft rep and a rep from Abbot finish supplies contacted me and gave me a demo that day. They pretty much said what both of you have stated. We sprayed a panel and it came out very nice.
