UV Resistant Stain / Topcoat Recommendation for Exterior Door
9/29/22
Tyle Johnson Member
Our customer on a current commercial project has requested that we finish a solid wood ( Mahogany) main entry door that they have ordered from a third party vendor.
The door will face east and will receive direct morning sun.
Typically, we use ML Campbell Dye and Wiping stains applied and mixed with B10 Base. For UV resistance we would normally apply Sherwin Williams Conversion Varnish with the incorporated UV INHIBITOR.
We understand and have made it clear to our customer that no matter what is used on the finish of this door it will fade over time. This is a commercial project, and the door is the main entry into a restaurant.
We have a couple questions that we are hoping to get some opinions on.
- Can anyone recommend a Specific Stain product that has a significant performance advantage in resistance to fading in direct sun when applied on an exterior product?
- Any recommendation on Best performing Topcoat to go along with said Stain product?
9/29/22       #2: UV Resistant Stain / Topcoat Recomm ...
What is an acceptable longevity before it needs to be refinished, because it will need it in the near future.
9/30/22       #3: UV Resistant Stain / Topcoat Recomm ...
mauricio poli
You will need to apply a water based stain for exterior.
The best pigments are transparent iron oxide (yellow, red, brown) like chromachem 896
And an acrylic pu exterior top coat (like Polane SW with V66V29 catalyst
3 coats overall the door
10/3/22       #4: UV Resistant Stain / Topcoat Recomm ...
chemmy Member
You could use common sense with your client and have them order "2" doors, finish both and have one installed and the other on the ready when its needed, just make sure they order two color matched doors so as not to complicate matters.! As to pigments, the best are those that have been used for centuries and proven themselves to be "Permanent.! Those are raw and burnt umber, raw and burnt Sienna, yellow oxide, Pthalo blue, red, and green.... which were used all last century and before in wood finishing in Europe and America and across the globe.!
These can be had from Mohawks company. And elsewhere. HULS synthetic pigments will get the job done, they are good, but since they are " new" as compared to the earth pigments, time will tell how close they are to the old standards.! of course carbon black and titanium oxide are also permanent non colors you may need to tint or lighten any of the colors if and when necessary.!
As to top coats, my preference has been 2K over polyester, depending where your located, I could suggest brands, but most of my work was done in Florida, from the mid sixties to the early two thousands. If your in a high UV concentrated area like that, then I can help, if not those who have recommended finishes so far will suffice, keep in mind that SW ..WW varnish yellows when in direct sunlight, where as a good exterior grade 2 K like they use on cars etc., will last at least a decade or more with daily strong sunlight on it for the entire day.!
If I can be of further assistance let me know.
Chemmy
12/12/22       #5: UV Resistant Stain / Topcoat Recomm ...
Jon W Member
To minimize fading, you will need to get a colour match using non-dye pigments. All dyes breakdown over time with UV light. 844 colorants made from oxides like TW, YO, RO, BU, etc are much more UV stable which is why they are used as impregnating agents in exterior wood projects. Get as close to the colour as possible in the stain match using oxide pigments and let the customer know that this is as close as it's going to get unless they want the colour to fade in a few years. An exterior grade 2k poly with good UV inhibitors that you can lay on a few thick coats of would help as. Check with Gemini about their Sirca product line.
7/9/23       #6: UV Resistant Stain / Topcoat Recomm ...
Steve  Member
SW Conversion Varnish is an interior finish and will not hold up in exterior conditions.
