Kremlin pump
12/30/22
Jim b Member
Already have older kremlin 10/14 and cat 10/14 pump,looking to add another and want to jump on the kremlin free gun with complete purchase of pump and gun.is this the time to go with the smaller egos pump or just the 10/18.I shoot all ml Campbell and will be trying out milesi if that helps.do I need one larger pump?
12/30/22       #2: Kremlin pump ...
herb johnson
if you are going with milesi wb, they tend to be pretty thick but have a false body, thixotropic, if you have the bucks going with a14-1 or 15-1 is all you really need no need for a 30-1, waste of money imho.the milesi i have sprayed do well at about 900 hydraulic pressure. good luck herb j. btw how long does the free gun promo last with krenlin?
12/30/22       #3: Kremlin pump ...
Jim b Member
End of day(year)buy set up get another excite gun and tip10c18 3,000and 15c25 3550
12/31/22       #4: Kremlin pump ...
I would go with the biggest pump you can afford.
Reasons being, you can use it for any very viscous coatings you may shoot in the future.
Less shear on thicker coatings.
Less air required if you do any finishing on site.
Pump cycles less , so longer between rebuilds.
1/1/23       #5: Kremlin pump ...
1/1/23       #6: Kremlin pump ...
Jim b Member
1 wish I could swing the Wagner cobra diaphanous pump but big bucks there
1/1/23       #7: Kremlin pump ...
herb johnson
depending on how often you change colors, solvent saving machine i bit the bullet and does save me a lot of time and money on solvent and color change but depends on what your finishing schedule is. great pump happy holidays
1/1/23       #8: Kremlin pump ...
I have heard nothing but good about those pumps. I would like to get one of those pumps as well. I don’t have a dealer anywhere close to me so I have never even seen one in real life.
1/1/23       #9: Kremlin pump ...
Yavuz Member
Definition of a beast.
Purchased a year or two ago from CET INC.
CA tech 14/1 and Cobra made great team since.
1/1/23       #10: Kremlin pump ...
herb johnson
they are virtually trouble free pump, main thing is to change the internal oil which is very easy. just don't run them dry , should be a lot of video's on them and very little to no support needed. pump will run easily on ten psi of air.
good luck herb j
1/2/23       #11: Kremlin pump ...
Herb,
Thanks for the info, just wondering what the difference between the 40-10 and the 40-25 is?
1/2/23       #12: Kremlin pump ...
herb johnson
same 40-1 pressure ration, the 25 has more delivery which you most likely won't need the 10 can easily handle 3-4 guns with a 11 or 13 tip
1/2/23       #13: Kremlin pump ...
Herb,
Thanks for your reply, I only work by myself these days and I only spray water base as well.
