humidity control
2/25/23
Jonathan Mahnken
I always seem to get in a bind with my WB top coats this time of year (micro air bubbles, craters, and wrinkling mostly) when the weather is freaking out and the humidity drops below 30%. This last week I went from 70-80% humidity to 10-15% humidity in less than a day. I have forced heated air coming into the room, and good exhaust, but the only way I can attempt to control the humidity is by mopping the floor, and this does very little. Is anyone else who sprays WB having these kinds of issues? and if so how are you overcoming them? Is there a way to consistently increase the humidity when you have that much air movement going on
2/26/23       #2: humidity control ...
Can't put a humidifier in line with the forced air. Set it at max not the humidity you want because of the constant air movement.
Just thinking out loud, I don't use waterborne.
2/27/23       #3: humidity control ...
Jonathan Mahnken
Thanks Leo. I dont know much about hvac. I had the unit professionally installed. Is there such a thing as an inline humidifier for a forced air furnace?
2/27/23       #4: humidity control ...
Absolutely. Just about any house that has a forced air system will have one.
As an example
2/28/23       #5: humidity control ...
nicko
you could also use a free standing humidifier that way you can just use it when you want and where you want and not blow humid air every time your furnace kicks on.
2/28/23       #6: humidity control ...
As soon as he turns the fan on it's gone if you use a free standing. The inline units are adjustable and you can turn them off if it's a humid day. Or maybe it'll work as advertised and keep the airstream at the preset humidity level.
2/28/23       #7: humidity control ...
Jonathan Mahnken
Leo I clicked your link, they seem to be very reasonably priced. Now just to pick the right unit
2/28/23       #8: humidity control ...
I'm sure there's hundreds of different types. I was just throwing you an example. I have no idea about that unit other than I've trusted Honeywell for years to have decent products. Essentially it's just a controlled mist-er
