CAT pump sticking
3/31/23
I have a CAT pump that has started to stick in the up position. I can push up on it and it will come back down. It doesn't always do it, just some of the time. Wandering if someone might know what to look at. Thanks
3/31/23       #2: CAT pump sticking ...
CraigM
Is the lube cup full? Is the lube clear or cloudy? Is there finish stuck to the piston? Could be time for new seals.
4/1/23       #3: CAT pump sticking ...
herb johnson
so here is your issue....cat has had issues with this air motor , especially if it is an older pump. they have an upgrade kit which is on their website . also, your wet cup being dirt has nothing to do with it although it is always good to keep an eye on it as it is a sign of A. the cartridge packing is going bad or B. if you have replaced the cartridge and it is still leaking, most commonly it is because the hard chrome has diminished over time with wear and the thickness of the hard chrome will allow material to bypass the rod and packing
good luck
herb j
4/3/23       #4: CAT pump sticking ...
Thanks, I will try to get an upgrade kit.
