Replacement spring for MVX Spraygun (found)
4/1/23
My MVX gun has been slow to shut off when I let go of the handle for months. Most of the time it works well but then it'll act up and not shut down quick and leak a stream of finish which really makes it hard to spray a nice finish.
Looked at a rebuild kit and they are nearing $700 now. More parts than I need. But that's where the springs are. I went to a spring website and found nearly a perfect match (LC 049D 12 M). They have a SS and Music wire version. If you use waterborne get the SS, but it's a bit weaker than the MW spring and I don't know the true specs of the original spring, other than it's magnetic.
I also got the trigger return spring (LC 041GH 05M) but it didn't work. The specs were good other than the hole size which is slightly to big and it gets stuck. I'm betting I can bend the start and finish coils to make it work but they don't have a drop in replacement.
But I got the spring I needed and the spraygun is back in operation baby!
MVX Needle Spring LC049D12M
4/3/23       #2: Replacement spring for MVX Spraygun ...
chris
if you need i have a MVX gun i no longer need. i upgraded
4/3/23       #3: Replacement spring for MVX Spraygun ...
Jim b Member
What was upgrade xcite?wagner?I never liked the mvx,the old Mx over that
4/3/23       #4: Replacement spring for MVX Spraygun ...
Chris
I have an xcite using with kremlin 10-14
4/3/23       #5: Replacement spring for MVX Spraygun ...
I have no problem with the MVX gun. Fits my hand nicely and the weight is good. Trigger pull doesn't fatigue my hand so long usage isn't an issue. I think it's about 15 years old now.
5/25/23       #6: Replacement spring for MVX Spraygun ...
dar
look at viper gun, total finishing supplies, an excite copy sprays just as good 600$ with air cap and choice of tip
