Guffey System
3/11/23
gary
Anyone using the Guffey System in the finish room?
5/1/23       #3: Guffey System ...
Logan
Just got one!
Is there something in particular you are trying to find out?
5/1/23       #4: Guffey System ...
gary
No. I have had it for a while and love it and keep on adding more. Just wondering if anyone else is using it. I have the Pivot Point system. Do you have that or the Pivot Line?
5/7/23       #5: Guffey System ...
Logan Member
We have the pivet line but haven't fully installed it till today,so for the last 2 weeks I have been using my carts as basically the pivet point.
But I've been loving it,for us we are able to get a set out in half the amount of time with about 40% paint!
6/2/23       #6: Guffey System ...
Eduardo Member
Website: http://beautifulfinish.com
I’ve had my pivot line for about a year now and has been a game changer in my shop. I am really happy I pulled the trigger buying it and can assuredly say it already has paid itself twice at least.
Get it.
7/13/23       #7: Guffey System ...
Eric
We have been using the Pivot Line for 2 years and keep adding on to it. It has helped our throughput greatly! I wouldn't go back to finishing flat for anything now and trust me, I was skeptical. Spraying all surfaces of a door at the same time saves a lot of time and handling. Also, the guys at Guffey Systems are awesome! And no they didn't pay me to say that. We have just had a great experience with them.
12/15/23       #8: Guffey System ...
Color Inc
I have used this system and not a massive fan. Although can be useful.
The problems are thin paints and box coating. This takes much more time than spraying on the flat. Hanging I have to let the paint tack up more which causes texture issue with certain cvs. I will say lacquer, polys acroma and the older kemvar lines are very good with this system. Using torino, resistance, Axalta and the newer SW coatings are time consuming and do not look as good as products on the flat. Spray stains can give good results but can also lead to halos in the profiles if not careful.
If your in a production setting and choose your products wisely you can really do well with hang lines. But higher end custom..I can't say I'd use it.
