Sata gravity gun
6/8/23
Joseph Eultgen
Anyone hVe any suggestions on a sata or kremlin gravity gun ? Model number? Needle size for nitroceulous lacquers and water born.
Thank you
6/10/23       #2: Sata gravity gun ...
Dave Edgerton  Member
Any of those are perfect. All depends on budget. 1.3 needle
6/20/23       #3: Sata gravity gun ...
dar
harbor freight, makes a sata knock off called black widow, 200$ sprays great, if you are only spraying nitro I would buy one, get the HTE model not hvlp one comes with 1.3 cap
7/17/23       #4: Sata gravity gun ...
Nick Sinderson
I'm a Sata spraygun fiend.
I own and use 7 of them in the shop; 3 gravity guns and 4 pressure feed guns.
Upside;
Very durable, very fine atomization, great finish quality
Downside
Fine atomization = lots of overspray...not the most material efficient guns...doesn't bother me but expect some overspray fog to linger in the booth beyond what a AAA set-up would.
I use 2 of the gravity guns to spray solvent based material on small jobs ( CV, 2k poly, vinyl sealer. These are set up with 1.4 needles and nozzles.
One l use to spray small WB jobs, it's set-up with a 2.0 needle and nozzle.
The 4 pressure feed guns l use to spray larger WB jobs with a 2 gallon pot. These are set-up with 1.1,1.3, 1.5. needle nozzles. Since l switched to a Euro WB material l almost never use these set-ups anymore as the euro WB 2k poly sprays great out of the AAA and 513 tip.
