cleaning wood
6/26/23
chris
What is a good tool to powerwash furniture before painting ?
6/26/23       #2: cleaning wood ...
None
6/26/23       #3: cleaning wood ...
Matt Calnen
A power washer!
6/26/23       #4: cleaning wood ...
Mastercabman
I usually get a 5 gallons bucket of elbow grease
7/21/23       #5: cleaning wood ...
FGT CABINETRY LLC (IOWA) Member
When choosing a power washer for furniture, it is important to consider the size of the furniture pieces you will be cleaning, as well as the amount of dirt and grime that needs to be removed. You should also consider the budget you have available.
No matter which power washer you choose, be sure to use a low pressure setting to avoid damaging the furniture. You should also wear safety goggles and gloves to protect yourself from the water spray.
Here are some tips for power washing furniture before painting:
Start by cleaning the furniture with a mild soap and water solution. This will help to loosen any dirt or grime that is difficult to remove with the power washer.
Use a low pressure setting on the power washer. A high pressure setting could damage the furniture.
Start at the top of the furniture and work your way down. This will help to prevent the water from running down and dripping onto the furniture that you have already cleaned.
Be careful not to get the power washer too close to the furniture. This could cause the water to damage the finish.
Rinse the furniture thoroughly with clean water after you are finished power washing.
Once the furniture is clean, you can start painting. Be sure to follow the instructions on the paint label carefully.
