Flatline Pumps
8/15/23
homebru
I'm setting up a new-to-me Makor K Two flatline.
Currently spraying WB acrylic, but likely moving to poly soon.
At AWFS, the Kremlin guys told me I want 20c50 pumps. All of the setups I see online to look at are utilizing 20c100's.
Anyone have experience sizing these? The Makor has two groups of 4 guns.
8/16/23       #2: Flatline Pumps ...
herb johnson
sure, what size tips are you planning on running.......that info is key to sizing out a pump plus are the pumps going to be located near the flatline or do you have paint kitchen you will be pumping from? and how far away is from the flat line.....
8/16/23       #3: Flatline Pumps ...
homebru
Thanks Herb,
Currently spraying with .010 tips mostly.
The pumps will be located close to the machine, 10'-15' of hose away.
8/16/23       #4: Flatline Pumps ...
herb johnson
so look, that is a not a huge tip, .279 († 0.011) 9.5 (0.28) 12.5 (0.037), the .037 is gpm/minute using this as a guide only, from a graco chart on aa guns, .037 gpm x 4 guns x does not equal very much flow. as far as sizing a pump, at 100 psi using extreme number"18 oz total for 4 gun."...using a 50% duty cycle is a good number. a 20-50 is Fluid delivery (30 cycles) 0.4 USgal......... at a high , 18oz per minute this pump can easily delivery 30oz a minute at a 50 percent duty cycle so this pump can easily handle it...... also the tip chart uses water as its measure stick for fluid, thicker fluid, less flow..........if you are going to be using a 2k with a catalyst in the future i would also investigate an enclosed pump , enclosed piston rod etc to prevent crystallization on the rod etc like the wagner cobra pump which is a double diaphgram pump and would make sense at an early stage of the conversion....also check wagner industrial spray eqpt, built in germany and is a very good value. any more questions just let me know,, just to summarize the 20-50 using the tip chart as guide will be runnning at 25% duty cycle max,,,,,
8/16/23       #5: Flatline Pumps ...
herb johnson
you could easily get away with a 20-25 pump, but check out other mfg. i believe there is much parity in the pump and spray eqpt world thinking of binks, graco, kremlin and wagner.......if you have kremlin they make great eqpt but their part prices are way way higher than other mentioned above. good luck herb j.
8/16/23       #6: Flatline Pumps ...
homebru
Awesome, thanks for all of the info herb!
