Color Matched Caulk
9/19/23
Ben Zacharias Member
Website: http://www.vangarde.com
We shoot ML Campbell Magnamax and are in need of color matched caulking for a few projects. All of the 'diy' tubes we have found, require water based paints to be added to them. Does anyone know of a simple option to make our own color matched caulking by adding the exact lacquer we used to spray the job?
9/19/23       #2: Color Matched Caulk ...
Why do you want to add a clear finish to the caulk? Add a universal colorant or dye powder. Any time you add a color to another product, the color intensity will change. Ask your ML Campbell shop to help you.
9/19/23       #3: Color Matched Caulk ...
We do not want to add clear to the caulk. We are looking for some type of caulking that we can add our pigmented lacquer to, so it will match our top coats. All the "mixable" caulking that we can find requires water based pigments. If you happen to know of anything like this please send over the product info.
9/20/23       #4: Color Matched Caulk ...
Jim Knowles
I don't have the answer you are looking for.
Have your paint store match the MLC color in latex paint. Put that in latex chaulk. Apply it last, over the top of your MLC. If you spray over the latex chaulk. There is a good chance it will crack.
9/21/23       #5: Color Matched Caulk ...
Chemmy  Member
You seem to not know a lot about color, which is par for the course. For instance a pigmented finish will change color depending on the mil thickness of coating you apply. If your applying multiple pigmented layers, then with every layer the color will change to a small degree. On the other end is a thick caulk, that will most likely be much thicker than the applied sprayed coatings. So unless both the caulk and the sprayed coating are of equal dry thickness, made with the same pigments, there will never be a perfect match.! You can run a sample of your coating to prove this point to yourselves, spray the surface with as many pigmented coats you normally spray, then tape half the surface off and then spray that many coats again on the exposed half let cure, unmask the taped side and inspect it in indirect sun light, you will see that the now more heavily pigmented side does not look the same exact color as the original.
Now, if your needing caulk to fill voids between adjacent
Surfaces, such as to fill cabinets being hung on a wall, etc., the color difference will be greater depending on the width and depth of the void, because the thickness of the caulk will be much thicker than any normal sprayed surface, outside of epoxies or polyesters, etc. On the other hand, if your using it to fill very fine voids such as two or more matching panels, you may get away with it, especially if you first fill the void with a color that is very close to your substrate color, and draw down a little below the color caulk you apply.
In actuality, I personally would just fill and sand and either hand touch up or mask off and spray the filled voids with the same spray applied coating I was already using, and if necessary, clear coat the whole project.
But that's me....
9/22/23       #6: Color Matched Caulk ...
Bozzy Member
Most paint stores offer color matched latex caulk. The sheen is always going to be somewhat glossy, unless you can get sanded caulk.
What are you planning to caulk?
9/22/23       #7: Color Matched Caulk ...
Jonathan Mahnken
check out color rite caulking. they do custom color matching.
