SW gallery
10/26/23
oth Member
Anyone using SW Gallery? 1k waterborne they claim to have the properties of a 2K... thoughts? Bought a gallon of clear to try it out
11/1/23       #2: SW gallery ...
Jim Kolar
We just shot this product this product with nice results. SW wood primer with two topcoats of Gallery. Graco 395 with a 3-12 fine rack tip. The color was an off-white color. Face frame flat panel doors typical.
11/10/23       #3: SW gallery ...
mike
I recently was handed a sample gallon by the local SW to try. I was really impressed. I normally use post cat SW conversion varnish in colors and clears. I have no experience with any other professional finishes or other water based cabinet finishes but had heard about differences in technique and equipment. I have used the Gallery in white and clear . It acted just like the CV in spraying; flowing out with almost exactly the same properties. Only difference was it took a slightly longer to dry. I used the white sample gallon only for test pieces and stair railing but then went through a gallon of clear for a job as a test. I loved the lack of smell and water clean up. I did notice the gun tip dried over more quickly and had to watch that. As it was i needed to spray my stair handrails at the time and used the gallery. It is hard and smooth with no signs of wear after several months now. At $85 per gallon its a bit more than CV but no thinner needed or catalyst. I am seriously thinking of using it exclusively. Any one else using it? ps i used it as self priming and did use 3 coats to get the build i wanted but i'm still new to it. And i use a gravity feed cup gun
11/11/23       #5: SW gallery ...
Oliver
$85/gallon? Dang, I walked out for $140 with tax and fees. By local SW you mean your local paint store or you local commercial shop?
I've only sprayed a bit of clear on a shelf to test it out, flowed great. Only did 2 coats and to the casual observer it looks and feels done. Was planning on using a less expensive tintable primer on opaque jobs.
11/11/23       #6: SW gallery ...
mike
i am only a 1 man shop so i dont think i'm getting super special pricing or anything. I was thinking list was only $100 or so. This was from a local regular SW consumer store. I usually need to go to the next town to a store that stocks CV products. I would not call either store a commercial or industrial store but the 2nd one definitely has many more cabinet shops around it. And yeah at $140/g i would think twice too
11/12/23       #7: SW gallery ...
Oliver
Where are you located? Hard to imagine they'd put a 60% premium based on region but maybe that accounts for some of it.
11/12/23       #8: SW gallery ...
mike
harrisburg/hershey central pa area
3/24/24       #9: SW gallery ...
michael l wenger
old post but i need to update some info i said previously. Apparently, the original gallon of Gallery i got was given at a 'promotional price'. When i recently went to buy more it was $135.00 and that is the going price although after i balked at it they said i could get in on 'bulk' pricing and it would be around $100 a gallon. Still not satisfied, i went shopping and checked in at my Benjamine Moore dealer and they had Gemini Evo Eclipse waterborne which i test sprayed and felt was similar to the gallery. Going to try more of it on future jobs at $85 a gallon.
