CV Finish Questions
10/28/23
howard
Website: http://woodcontours.net
Put Mohawk CV on tall red oak bookcases. On the underside of one shelf there was a small area where the finish formed these small very thin skinned bubbles that easily popped. Any idea what would cause that?
The other question is the bottom face frame sections and toe kicks have a rough texture, the rest of the piece came out fine off the gun. I had them on a floor level turntable. I thought maybe I was getting finish bounce back off the turntable. Would you suggest another way to do this?
All booth conditions were good, temperature, airflow, new material. Thanks for your help.
10/30/23       #2: CV Finish Questions ...
Wyatt
Most likely there was air trapped in the open grain of the red oak. Thin your material and spray lighter coats. The rough texture could be from bounce back as you stated or from not heavy enough of a coat. Get the cabinet up off the ground where it is easier to spray and see how heavy you are putting it on.
10/30/23       #3: CV Finish Questions ...
Eduardo Member
Maybe add a bit of retarder?
10/30/23       #4: CV Finish Questions ...
Tony
On red oak, that is most likely solvent pop. Air trapped in the open grain-finish flashes and skins over, then the air escapes and causes little "craters". Thinner coat, or add some retarded to slow down drying to allow air to escape.
