installing wood veneer
11/12/23
dave Member
I need to re-veneer an antique table (see similar table pic) and I need to know how to do it. I dont think contact cement will work because it would leave a gap on the edge. I was thinking of carpenters glue, pressing it and then using a router to rework the edge again. The veneer I have is real wood, no backing.
11/13/23       #2: installing wood veneer ...
Lary Sanders
Hi,
Glue: I agree not contact cement.
If it's an antique then hide glue (liquid) is more historically beneficial and reversible.
PVA/ "yellow glue" is useful in most cases. I typically choose a slower set version than the standard furniture glue. If desired you can buy colored or dye it yourself to minimize anything visible on the edge. However with good clamping that should not be a problem.
Clamping: It sounds like you have this planned. it is important the the press is even over the whole surface; vacuum, platen, etc. Not just cauls and edge clamping.
Edge: I would not route the edge veneer. The shape you show would mean you'd have to route against the grain in places or back route. There is a good chance the thin veneer would tear and/or you might hit some of the base table. I would use hand planes and/or files for the final edge fitting.
Good Luck
Lary
