Spraying Bookcases
11/29/23
howard
Website: http://woodcontours.net
I've got 3 five foot tall and 2 6 foot tall bookcases to spray and my finishing room is not that big. Normally I prefer to spray with the backs off which keeps the overspray off the sides and me. But given my space constraints it would save time if I could do it in one shot. Appreciate your thoughts on this and if it's better to just do the backs separately that's what I'll do. Thanks
11/30/23       #2: Spraying Bookcases ...
sam pettit  Member
You really answered your own question Howard, it's always best to go with what gives the best results, which is removing the back, as noted.!!
12/1/23       #3: Spraying Bookcases ...
herb johnson
the reason you take the back off typically is the sprayer you have is creating too much bounce back / overspray. if it is within your budget get an air assisted airless or airmix unit. the difference between those and either hvlp or air spray atomization is significant. and you will use much less material.
good luck herb j
12/2/23       #4: Spraying Bookcases ...
Yavuz Member
Herb Johnson
Whats the difference between air assisted airless and airmix?
12/2/23       #5: Spraying Bookcases ...
herb johnson
none imho, i have sprayed binks, wagner, and kremlin, i cannot tell them apart. they all use an airless style tip and introduct air into the side of the pattern to remove the fingers or tails, the heavy lines at the ends of the pattern. with true airless, you keep introducing pressure till the tails disappear, that introduces more forward velocity than necessary creating some dry spray and overspray......air assist or airmix is a much much softer spray than airless. good luck herb j. btw, i am sure their are airmix users who will dispute my claim but everyone has their preference
12/2/23       #6: Spraying Bookcases ...
Yavuz Member
You are right ! Airmix is either a fancy name or system for their pumps and guns or something different than the AAA unit we all use.Above my pay grade :) Hard to guess since i don't have a Kremlin.
Honestly did not need a reversible tip for my units and flat tips are all i use.No difference IMHO.Just easy cleaning maybe ?Than again i use very fine double sometimes triple filtration and no dirt at the end of the line.
10 psi on the gun barely moves the hair on the surface :)
Book cases or boxes are no problem spraying with AAA. No need to remove the back as long as your gun moves easy in the project.
Pleasure Herb.Yavuz here btw.
12/2/23       #7: Spraying Bookcases ...
herb johnson
yavuz no difference imho, "all use the same type of atomization." just like a refrigerator, kenmore, ge , etc good spraying herb j
