Spraying Solid Wood Raised Panels
1/9/24
howard
Website: http://woodcontours.net
I haven’t done a lot of these but the ones I have, as the panel shrinks sometimes it reveals that ridge of the finish where the panel met the rails and stiles. I usually spray solvent catalyzed lacquers and CV. If I pre finish the panel, how do I then put the finish on the rails and stiles, without getting a too thick film build on the panel? Also with pre finishing, with CV there is a time limit (4hrs.) so pre finishing means a lot more sanding for good bond if I can't get everything done in time. I'd like to do more of these but this issue is holding me back. Appreciate it if you could walk me through the steps you do. Thanks for your help.
1/9/24       #2: Spraying Solid Wood Raised Panels ...
Jim Clark Member
I always stain the panels first, spray a coat of sealer, sand the sealer then
install them into the frame. then I sand the rest of the door stain it and spray
everything at once.
It's also easier to stain the inside of the frame before installing the panel.
1/9/24       #3: Spraying Solid Wood Raised Panels ...
I stain or (color) prime the tongues of the panels before assembly. Then clear or prime/paint as usual.
1/14/24       #4: Spraying Solid Wood Raised Panels ...
Dave Edgerton  Member
Are we talking cabinet doors? Should have a very small radius from the cutters on the rails and stiles. Slap on the stain, wipe, seal, sand, topcoat. Done.
1/15/24       #5: Spraying Solid Wood Raised Panels ...
Yavuz Member
Not all the profiles has eased edges. Most of are square and no gap in between unfortunately. Your best bet is stain and seal the panel before assembly. That's what I do. Either stain or solid paint.
