ICA Polyurethanes
2/8/24
Color Inc Member
Haven't sprayed ICA in some time but almost all the polyurethane I shot melesi, ilva and sayerlack, I have always did a wet on tack coat. My paint distributor told me to scuff in between coats while using ICA. Any thoughts on his comment?
2/8/24       #2: ICA Polyurethanes ...
Bob Niemeyer  Member
Lots of variables here. It depends on what product you are spraying. For best flow out a 4mil wet coat is desired, but that depends on the viscosity you are spraying at.
All of the products have a "wet on wet" window and if you recoat with in that time no sanding required.
The "wet on wet" window varies based on product used, catalyst used and temp in the shop.
I spray tons of ICA and am also one of their Tech reps, if you need more info you can ask here or call or email me @ bobniemeyer@icanorthamerica.com
2/17/24       #3: ICA Polyurethanes ...
dar
bob is super knowledgeable, but ica is a pain to deal with, no pds on website, in fact there website is awful. distribution is terrible and is expensive might be better off with a different 2k , ica is good stuff though
