SEALING 1 3/4" DOOR EDGES
2/15/24
Orin N Zelenak Member
What are you using to seal the bottoms of door edges that need to get trimmed on site?
2/16/24       #2: SEALING 1 3/4" DOOR EDGES ...
on painted doors we've always used Bin shellac primer. dries wicked fast. it's the best moisture sealer, so it's good for bathroom doors. if you are doing clear finish jobs, you could use Sealcoat. It's a universal shellac sanding sealer.
2/16/24       #3: SEALING 1 3/4" DOOR EDGES ...
Chemmy
Always used 5 min. Epoxy (Mohawk) if it was just a few, or 12 hr. If it was many more, on the 12 hr. We used a heat gun to make it dry faster, just make sure not to bubble it...!!!
2/16/24       #4: SEALING 1 3/4" DOOR EDGES ...
I looked at Shellac and saw it has a low perm but still around .6 - 1.2. Epoxy is very low perm and also a hassle. Last night it occurred to me to try a really heavy foil tape
2/17/24       #5: SEALING 1 3/4" DOOR EDGES ...
dar
shellac is not a good moisture barrier, there is no need to use it, except to seal in fisheye
2/18/24       #6: SEALING 1 3/4" DOOR EDGES ...
Jim b
Anchor seal
2/18/24       #7: SEALING 1 3/4" DOOR EDGES ...
Jim - any particular Anchor Seal product?
2/18/24       #8: SEALING 1 3/4" DOOR EDGES ...
Jim b
Anchorman one word they use for end checking in mill yards .waterbase,water-based, it up
2/19/24       #9: SEALING 1 3/4" DOOR EDGES ...
Jim b
Sorry anchorseal one word
