finishing time expectations
3/9/24
Quicktrim
Website: http://jkinteriorfinishllc.com
Hello finishing experts.
I have only had finishing in house for about two years.
The setup is as follows:
2500 sq ft . global finishing solutions closed face booth, foam suppression, denray downdraft for whitewood and primer / sealer sanding, dust free drying / flash off room, 3 CA tech 14 : 1 AAA pumps, 1 Kremlin eos . lots of carts and racks, air random orbits adn 3x4 square sanders.
So not the most advanced setup but what I could afford at the time.
Currently using ML products , Claw lock for primer , Klearvar for stain topcoats, woodsong for stains , stealth for color topcoats.
My question is how ling should it take for a kitchen to get sprayed start to finish ? I am talking average kitchen , shaker doors, MDF or 5 piece maple with MDF panel. Average 25 - 30 cabients so 40-50 doors and drawer fronts, a couple reffer end panels , five sticks of crown backer and five sticks of crown , five to eight toe kicks, a few fillers.
Currently my guy spraying has experience but by no means a carrer finisher. They are putting good looking product out but with two guys in there it is taking a solid week to get the finishing done for one kitchen.
Doors come in from Cal door so pretty clean to start with. Does 80 man hours seem excessive for finishing this amount ? seems to be taking quite a bit longer than I am comfortable with.
I appreciate any insight that you carrer finishers have as I want to make the finish room a profitable part of the business.
3/9/24       #2: finishing time expectations ...
Bob Niemeyer  Member
The first thing I would tell you to do is work with your guys on several jobs from start to finish. Then you will have a "feel" of what it takes to get the job done.
Then sit down with them and ask them "what do you need to get things done more efficiently"
I would love to know what the outcome is. Most of the time it is help to sand and speeding up dry times.
Good luck !
3/10/24       #3: finishing time expectations ...
Antonio
That sounds like 1 day worth of priming; 2 days worth of top coating.. with other work getting done between dry times. 3 man finish shop with additional sanding help when needed. I always try to keep someone; wether myself or apprentice spraying at all times. The jobs we do are a lot bigger though 200+ doors. Your setup is similar to ours.
3/10/24       #4: finishing time expectations ...
I'll bet good money they are spending way too much time handling parts. As mentioned, put on a mask and spend a week in the booth. It's very likely not the guy unless you have him tied to the wrong kind of production spray equipment. Give him high volume spray equipment and methods of passing parts through the booth faster. Besides, finding a new finisher will really cost you and nearly impossible to find.
3/11/24       #5: finishing time expectations ...
Dave Edgerton  Member
I agree its not the person dragging their feet, its usually in setup and handling.
3/11/24       #6: finishing time expectations ...
gary
I switched to a fairly inexpensive hang line and our finishing efficiency skyrocketed.
3/11/24       #7: finishing time expectations ...
JM
I have one finisher, he will do a job like that in about 3 days. Whitewood Sanding, 1 coat primer, 2 top coats with scuff sand between all finish coats.
3/11/24       #8: finishing time expectations ...
Quicktrim
Gary ,
Did you have any probl with runs when using CV ? I see what you are saying the dry time as you do one side at a time stinks , what about sanding between coats ? Do you just remove the hinge clips and then reinstall after sand ? Also I can see benefits of not having all that open square footage for dust to set in as it's flashing off.plus no marks on backs from the dry racks .
3/11/24       #9: finishing time expectations ...
gary
We were very surprised with how short the learning curve was. We had some runs where we had to double coat when rails met stiles on doors and face frames but worked them out. It is not necessary to remove clips and other hangers but it is fast to do if you want to. Dust and rack marks are a thing of the past. I wouldn't want to go back to spraying flat...no way...not ever.
7/28/24       #10: finishing time expectations ...
Frank Garrido  Member
Website: http://www.cabinethero.com
Definitely do a job study , it’s the best thing for you take the time to ensure the job or tasks performed are structured and set by your standards . Your standards of quality and efficiency will
Really become clear to you as you see what areas require a lot more attention to detail and what areas are more productive . For example all the one sided components like Fillers , Moldings, toe kicks, panels , usually require the least amount of prep and visual inspection and time . One of primer and two coats of a top coat should see all these components out in one day . Having part of the job being completed especially parts that are necessary for installation does two things .
It demonstrates to your crew the progress and productivity which should be achieved for your business .
The other half of the job Doors and boxes ( if they are face frame) is s as mother study for you to break down for them .
Again once you see the areas of attention you will be able to understand what is important requiring more time and what is less important . Like the front of a Cab door versus the back !
Your instructions as to how they will approach the jobs will ensure the productivity to ensure profitability without compromising quality .
This structuring of how the work is to be performed is your responsibility , it’s not automatic . Taking the time to this is vital , the sooner you do it the less time you will spend retraining your guys on how get the job done. They either don’t have
A clue on the costs of running a business or more likely it’s not their responsibility and they are just doing what they think is best , which is not always what is best for your business.
Set your standards is my
Advice .
7/28/24       #11: finishing time expectations ...
Quicktrim
Frank thank you!
That is great advice. I admit the buck has to start and stop with me. It is my responsibility to set them up for success. I was a twenty five year installer before I started this shop and at times the stress of getting all the parts to come together has been debilitating. I have tremendous respect for every shop owner who has been through the first three to five years. I thought I knew a lot about how things should be done from seeing everyone's product as an installer. I thought I knew better than most.
The harsh reality was that I had no clue as to what it took to get a product out the door quickly enough and with quality enough to make a decent profit.
