Ultrasonic cleaner
5/18/24
Jim Knowles
How do the users of AcraStrip cleaner, leave it in the machine or empty the cleaner from the machine after each use...?
5/18/24       #2: Ultrasonic cleaner ...
CraigM
I use Acrastrip 800, thinned 2 parts water, 1 part stripper. I leave it in my ultrasonic for multiple cleans and it doesn't seem to lose it's potency. The only time i change it is when it gets too sludgy at the bottom, so sometimes it's months between changes.
9/2/24       #3: Ultrasonic cleaner ...
matt  Member
I leave mine in the ultrasonic as well. I do heat it before I put parts into my ultrasonic. Also, AcraStrip is reusable, so if you filter the water/AcraStrip mixture to remove any large particles, you can reuse it (per their website). The key is heating it a bit to work faster. I also recommend leaving your guns in the liquid for a short time; I made the mistake of leaving a gun in there overnight or longer, and it pitted the chrome plating. The best option is to use heat, allow it to work, remove it from the mixture within an hour or less, and then clean your part using water and a brush.
